Problem Related to Photons with Mass
The discussion revolves around the calculation of photon mass and the resulting matrix transformations under Lorentz boosts. Participants express confusion over the appearance of minus signs in their results, with some suspecting typos in the reference material. After reviewing calculations, one participant concludes that the minus signs arise from the distinction between covariant and contravariant momentum vectors. Ultimately, they agree that the original problem's boost matrix may contain a typo, and clarity is achieved regarding the nature of photon mass, reaffirming that photons are massless. The conversation highlights the importance of careful calculation and verification in theoretical physics.
diffidus
I am trying to understand example 13.6 given in the book 'Quantum Field Theory for the Gifted Amateur' by Lancaster and Blundell. The problem is: Consider a massive photon in the rest frame so that P^μ=([m,0,0,0). If we boost the particle in the z direction to P^μ=([E,0,0,p) can we calculate the product of the polarisation vectors:
I have included the relevant equations below. I tried multiplying the matrices together but could not get the correct answer. Is there anybody out there that can help?
Before boost we have
Then using the Lorentz boost:
I want to calculate:
I tried multiplying the matrices together but I never get the stated answer which should be:
I get the stated answer except the minus signs. Just using the result of the previous example:
Hill
So I think you got your result by using the previous example values for ε as you have said. Then, I assume you carried out the product sum with with λ =1,3. Thanks for this answer, it gets me closer but then there is still the annoying minus signs, which makes me think there must be another subtlety and that worries me.
I think they are a typo.
That would be great, but I am not certain since in the book that I refer to, it also gives the product involving εε in terms of a projection operator:
and that
When I use this method it gives the matrix including the minus signs. So I am still not confident. Anyhow, thanks for your effort, it is really appreciated.
Could you show how it gives the minus signs? I don't see it.
Apologies - I looked back at my calculation and it appears that I managed to get a minus sign in there. I have redone the calculation and I now get positive values and so I am now completely on the same page as you. In the matrix quoted in the book - it must be a typo. Thanks very much for your help in solving a frustrating problem.
I feel a bit like a bad penny now but I have looked over my calculation and I can now see where the minus signs come from.
The problem is given in terms of a boost in the z-direction:
From this we get:
Which can be calculated independently using:
Using this second method the minus signs in the A matrix arise since in the projection formula the momentum vectors are covariant and so should be:
So for example:
Similarly for A30.
The bad news is this still leaves me with the original problem! The good news, however, is that I think I have spotted the issue.
In the original problem equation 13.29 gives the boost matrix as (multiplied by 1/m):
However, I think there is a typo here as it should be:
When this boost matrix is used and followed through the rest of the derivation everything is resolved - phew!
Once again thanks for your help with this it has helped me a lot as it got me to think about my calculations and, naively, I never considered typos.
From this we get:
So for example:
Similarly for A30.
Thank you for clearing this point. I think now that there is no typo at all, and the resolution for the minus sign in the original problem is the same: the polarization vectors in 13.30 are contravariant, but they are covariant in 13.40. This gives us the minus signs in the answer, doesn't it?
A photon doesnt have a mass. it's massless.
Yes. However,
(Lancaster, Blundell, Quantum Field Theory for the Gifted Amateur)
I remember this Lagrangian called proca lagrangian density. otherwise I cannot recall.
