I Problem with integrating the differential equation more than once
LagrangeEuler
Starting from equation
\frac{dy}{dx}=\int^x_0 \varphi(t)dt
we can write
dy=dx\int^x_0 \varphi(t)dt
Now I can integrate it
\int^{y(x)}_{y(0)}dt=\int^x_0dx'\int^x_0\varphi(t)dt
Is this correct?
Or I should write it as
\int^{y(x)}_{y(0)}dt=\int^x_0dx'\int^{x'}_0\varphi(t)dt
Best wishes in new year and thank you for the answer.
##f(x) = \int_0^x \phi(t) dt## so ##y(x) = \int_0^x f(x') dx' + const##
Thus, it is the second
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
