Problem with Limits using L'Hospital's Rule
  • Thread starter Thread starter CharlesL
    Limits
CharlesL
Determine the limit of
lim \psi\rightarrow1 of \psi^(1/(\psi-1))
Let y = \psi^(1/(\psi-1))
ln y = ln \psi^(1/(\psi-1))
lim \psi\rightarrow1 ln y = lim \psi\rightarrow1 of (1/(\psi-1)) (ln \psi)
Differentiate
lim \psi\rightarrow1 ln y = -1/(\psi-1)2 x (1/\psi)
lim \psi\rightarrow1 ln y = 2/(\psi3+3\psi2+3\psi+1)
ln y =1/4
y = e1/4
Does e1/4 = e?
L'Hopital's rule works for f(x)/g(x) and then you get f'(x)/g'(x). Try rewriting the step before you differentiate as a fraction and not a product.
Thank you for your reply.
I wonder which is the correct solution
solution (a)
ln y = 1/(\psi-1) x ln \psi
ln y = ln \psi x (\psi-1)
ln y = 1/\psi
ln y = 1/1
y = e1
or solution (b)
ln y = ln \psi / (\psi-1)
ln y = 1/\psi
ln y = 1/1
y = e1
I did it the second way, assuming you just didn't feel like typing out that you were still dealing with limits
Thank you Hogger for your point outs. Appreciate it. Have a nice day
Charles
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
