Problems with acceleration results established from equations of linear motion
In summary, the three cases of an object decelerating at different rates have results that are consistent with the equation of linear motion, s=ut+1/2at^2.
Agrech
I have 3 separate cases of an object decelerating at different rates. The aim is to find the acceleration for each case.
Case 1
Initial velocity: 1.663m/s
Displacement: 0.12m
Time: 0.139s
Case 2
Displacement: 0.12m
Time: 0.155s
Case 3
Initial Velocity: 1.663m/s
Displacement: 0.12m
Time: 0.24s
The attempt at a solution
Simply using the equations of linear motion (s=ut+1/2at^2) I got the following results:
Case 1: -11.5063m/s^2
Case 2: -11.4685m/s^2
Case 3: -9.69167m/s^2
Why? I expected the magnitude of deceleration to increase from case 1 to case 3
Also deceleration of 11m/s^2 seems excessively high. I need to understand this for an assignment due in a few days.
I've done this many times now and with different methods such as finding the final velocity first and then finding the acceleration but every method gives me the same results or at least the same pattern of the deceleration decreasing.
Hi,
imagine yourself sitting in a car moving with the given initial velocity and then applying the brakes. You do that three times. First time you need 0.139s, second time 0.155s and third time 0.24s. At which of the cases have you applied the brakes hard, harder, the hardest?
About feeling the 11m/s^2 excessively high: Compare it with g, the acc. due to gravity.
Since the displacement and initial velocity are constant, increasing value of t should be followed with decreasing value of a.
In janny's scenario, the moving car will travel 0.12m in the shortest time if no brakes are applied. The longest time will result with the largest deceleration.
Is your scenario similar? How did you arrive at your results?
@janny, Thankyou for your help. So far this is exactly my thoughts, in case 1 the brakes are applied hard, case 2 harder and case 3 the hardest. This is why I expected that case 3 would the highest magnitude of deceleration, however I consistently get case 3 being the lowest.
Regarding your comment about comparing the acceleration with gravity, that is exactly why I feel that is too high.
I agree with this but my results aren't showing that.
@lewando yes my scenario is very similar.
I arrived at my results by using s=ut+1/2at^2
Rearranged to a=2(s-ut)/t^2
And the results are in my original post
Agrech,
You have a sign failure with your calculations.
Its rather s=ut-1/2 at2 than s=ut+1/2 at2.
PS: Or as you suggested you use s=ut+1/2 at2 but bearing in mind that this would give -a.
Ponder this for a while: http://fooplot.com/plot/h238j2y69v
For this family of equations, no amount of deceleration is going to get to the 0.12m mark in 0.24s on the first encounter.
Maybe you can describe in more detail your experiment.
As one can see, the use and interpretation of plus and minus signs in Intro Physics are cause for much confusion. There is nothing wrong with the answers listed in the original post. The magnitude of the deceleration is the greatest when the time is the shortest, that is, when the brakes are applied the hardest. The 1 g deceleration is not too bad as long as you are buckled up for safety.
PhantomJay, in all three cases, the initial velocities are the same and the distance traversed is the same. I would re-assert that the shortest time occurs when there is zero deceleration.
As you decelerate while traversing the distance, you slow down and the time should increase accordingly.
At some large enough deceleration, you will begin to move backwards and not even make the 0.12m stretch.
I believe these statements to be correct, but I have been wrong before.
lewando,
Though that's exactly what I have thought so far, I must contradict, PhantomJay is right, I give it a trial prooving that mathematically:
the traveled distance in each cases is constant, i.e
ut1 +1/2 a1t12 = ut2 +1/2 a2t22
t1 +1/2 a1t12/u = t2 +1/2 a2t22/u
Now, let t2>t1 i.e there is a z from ℝ such that t2=zt1, hence
t1 +1/2 a1t12/u = zt1 +1/2 a2(zt1)2/u ⇔
zt1-t1 = 1/2 a1t12/u - 1/2 a2(zt1)2/u ⇔
zt1-t1 = a1t12-a2z2t12/2u ⇔
2u(zt1-t1 ) = t12(a1-a2z2) ⇔
2u(zt1-t1)/t12 = a1-a2z2.
Now, since 2u(zt1-t1)/t12 > 0 it follows that a1-a2z2 also must be > 0. But that in return implies a1>a2z2 and so a1>a2. Alltogether we see: t1<t2 => a1>a2. That is, the shorter the time the greater the magnitude of acceleration, as PhanthomJay suggested.
PS: a should be read as magnitude of a, for I couldn't find the magnitude dashes I have omited them.
When using the kinematic equation s = ut + 1/2at2, to eliminate confusion, realize this:
"a" is not a vector.
"a" is not the magnitude of a vector.
"a" is a scalar.
The value of the scalar "a" is determined by the x or y-axis acceleration vector that the equation is describing.
An acceleration of 10m/s2 in the positive x-axis direction would result in the scalar value of 10m/s2.
An acceleration of 10m/s2 in the negative x-axis direction would result in the scalar value of -10m/s2.
The terms acceleration and deceleration can also be a source of confusion. Recommend avoiding the term deceleration for now.
That being said, @janny, your analysis is correct. The interpretation of your result needs some thought.
For objects traveling in the +x direction with identical initial velocities as they enter a fixed distance interval, what you said is true:
Using actual scalar values:
a1 = 10m/s2 => t1 (shorter than t2, because of larger final velocity)
a2 = 5m/s2 => t2
In this case t1<t2 and a1>a2, in agreement with your analysis.Using another set of scalar values:
a3 = -5m/s2 => t3
a4 = -10m/s2 => t4 (longer than t3, because of smaller final velocity)
In this case t3<t4 and a3>a4, also in agreement with your analysis.
@Agrech--I hope you are still following. How certain are you of you initial velocity? 1.663m/s looks very precise and consistent. Was this measured or calculated? Reason I ask--if you recompute your accelerations based on an initial velocity of 1m/s, the results make more sense.
The SUVAT equations tell no lies. Barring a math error, the original answers are correct. The negative value of the acceleration implies that if the object is initially moving to the right, the acceleration is to the left. The paradox of why the shorter times yield higher values of the leftward accelerations is solved by realizing that there are two roots for the time in the quadratic equation; when both roots are positive, the given times at a positive displacement of 0.12 m may very well be occurring when the object is moving backwards to the left, having earlier already passed that point when moving right.
Related to Problems with acceleration results established from equations of linear motion
1. What are the main causes of errors in acceleration results from equations of linear motion?
The main causes of errors in acceleration results from equations of linear motion can be attributed to factors such as measurement errors, external forces acting on the object, and inconsistencies in the motion of the object.
2. How do measurement errors affect acceleration results from equations of linear motion?
Measurement errors, such as imprecise measurements or faulty equipment, can significantly affect the accuracy of acceleration results from equations of linear motion. These errors can lead to incorrect values for displacement, velocity, and acceleration, resulting in inaccurate conclusions about the motion of an object.
3. Why do external forces impact acceleration results from equations of linear motion?
External forces, such as friction or air resistance, can affect the acceleration of an object and cause errors in the results obtained from equations of linear motion. These forces can either impede or enhance the object's motion, leading to different acceleration values than predicted by the equations.
4. How can inconsistencies in the motion of an object affect acceleration results?
Inconsistent motion, such as sudden changes in velocity or direction, can also lead to errors in acceleration results from equations of linear motion. This is because the equations assume a constant acceleration, and any variations in the motion can result in incorrect values being calculated.
5. What steps can be taken to minimize errors in acceleration results from equations of linear motion?
To minimize errors in acceleration results, it is essential to use precise and calibrated measurement tools, account for external forces, and ensure consistent and uniform motion of the object. Additionally, performing multiple trials and taking the average of the results can also improve the accuracy of the acceleration values obtained from equations of linear motion.
