Problems with def. integrals/fundamental theorem
  • Thread starter Thread starter myanmar
    Theorem
myanmar
1. Find \frac{dy}{dx} and \frac{d^{2}y}{dx^{2}} if \int^{3x}_{1} \frac{1}{t^{2}+t+1}\,dt
I expect that I'd make u=3x, then du=3dx. I think when I differentiate, I'd end up with \frac{dy}{dx}=\frac{1}{3t^{2}+3t+3}. I think that \frac{d^{2}y}{dx^{2}} would just be the derivative of \frac{dy}{dx}
2. Find and classify the relative maxima and minima of f(x), if
f(x) = \int^x_0 \frac{t^{2}-{4}}{{1}+{cos}^{2}{t}}\,dt
I think to find max and min, I just need to find the second derivative and solve for zero right? Is the first derivative \frac{x^{2}-{4}}{{1}+{cos}^{2}{x}}?
Assuming that y is the integral expression in #1, then I guess you could use substitution, but it'd be easier just to apply the chain rule. But either way, you need to substitute u = 3x in place of t so dy/dx should be [1/(9x^2 + 3x +1)] * 3. I think it's a lot less confusing if you applied the FTC (remember the parameter t should disappear) by substituting 3x in place of t and then applied the chain rule to the upper limit of integration.
The second derivative is then just the derivative of 3/(9x^2 + 3x +1), which is easy.
For #2, you applied the FTC correctly but your subsequent reasoning is a bit flawed. To find the relative min and max, you need to find the zeros of f'(x), which you determined correctly. You could use the second derivative test to verify whether each critical point (zeros of f'(x)) is a relative max or min (or neither). Suppose x = a is a zero of f'(x). If f''(a) < 0, then f(x) has a relative max at x = a and if f''(a) > 0, then f(x) has a relative min at x = a. Of course just looking at sign changes prevents you from having to take the second derivative of f(x).
So I've got the first one now, it's quite easy due to the help I've recieved.
However, on the second one. I have my x values for the extrema, but I can't figure out the y values because I'm not sure how to take the integral of \frac{t^2-4}{1 + cos^{2}t}. I just need to take the def. integral from (0,2) and from (0,-2). Also, I need that integral because I can't figure out how I'd plug in values around 2 and -2 to figure whether they were max/min
You don't need to plug values in if you can figure out whether the second derivative is positive or negative at those x values.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
