Problems with lagged turbo and exhaust systems
  • Thread starter Thread starter beckliam4
    Exhaust Systems
Lagging a turbo and exhaust system may lead to turbo failure due to heat retention, which can cause expansion issues in the casing, bearings, and shafts. Historical issues with early turbo designs indicate that excess heat can damage bearings, suggesting that proper cooling is essential. Oil presence inside the turbine unit likely originates from bearing problems, potentially exacerbated by insufficient cooling from lagging. Keeping the compressor section cool is critical to prevent bearing overheating, and leaving bearings uncovered might improve cooling but could affect the lagging setup. Additionally, using specialized oil formulations that maintain viscosity at high temperatures may be necessary to mitigate these issues.
beckliam4
hello,
does anyone know if lagging a turbo and exhaust system would cause failure of the turbo. my thought is that on the lagged turbos the heat can not disperse causing early failure due to expansion of the casing, bearings and shafts. could it also effect the oil viscosity ?
any thoughts please,
DAL
Not sure if it helps any, but the first generation of auto engine turbos about 25 years back had the problem of excess heat frying the turbo bearings after engine shutdown. So the suggestion was to not turn off the engine right after driving, but to let it idle for a minute. Longer term, I believe the fix was to add a little oil reservoir to the bearing circuit, so the system could cope with the extra heat.
Given that the exhaust gas turbine which drives the compressor can run red hot, it is unlikely that lagging the components will introduce extraordinary additional stresses.
thanks for that, were having problems with our turbos after being lagged this is a resent upgrade. after we run them up were finding oil inside the unit where the turbine is any thoughts.
Oil inside the turbine unit pretty much has to come from the bearings, so there is an expansion issue in your case.
Usually in these installations one tries to keep the compressor section as cool as possible, no matter what the turbine temperature, so the bearing does not see the full turbine heat.
So there might be some improvement if the bearing is left uncovered, so it can cool down at a better pace, but it may impact the lagging installation.
Separately, you are quite right that the oil viscosity declines substantially at higher temperatures. There are specialized formulations that maintain their properties at higher temperatures, used in aero engines particularly.
You may need to consider these if you cannot fix the problem with alterations to the setup.
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
