- #71
- 24,492
- 15,023
You can take holomorphic functions as scalar fields (or their real and imaginary parts) in 2D Euclidean space. These are the "harmonic functions" with the properties described. It was only an example. Of course this mathematical phenomenon is more generally just Stokes's theorem for differential forms.Sunil said:There are Hilbert spaces of holomorphic functions, but they have nothing to do with field theory.
I'm talking about massless spin-1 fields in relativistic field theories. They are necessarily gauge fields, as can be derived from the representation theory of the Poincare group.Sunil said:And that's wrong. You can start from a vector field ##A^\mu## too.
There will be some problems with the implementation of the Lorenz gauge, but similar problems appear in condensed matter theories too if you have a continuity equation: If, say, the fundamental theory has exact particle conservation, and you want to have a field theory based on the density ##\rho## together with the continuity equation, it is not easy to reach that ##\hat{\rho} \ge 0## and that the conservation law is not even violated even by vacuum oscillations. Quantum condensed matter theory nonetheless works nicely.
You said repeatedly that local gauge symmetries can be approximate, but that's not true, because then they loose their physical meaning. This has nothing to do with (Dyson-) renormalizability or non-renormalizable effective theories.Sunil said:Please quote me in a meaningful way. I do not claim "a violation of gauge invariance" but usually write complete sentences. Like the following: Theories with vector fields ##A^\mu## with some approximate gauge invariance are possible. They may be non-renormalizable, but this does not make them invalid as effective field theories. But these theories will certainly not use the Gupta-Bleuler resp. BRST approach, but start with a definite Hilbert space.
No, massless vector fields must be necessarily quantized as gauge fields. For massive vector fields you are right.Sunil said:And that's simply wrong. You can make physical sense of vector fields if you start with a definite Hilbert space. Of course, you need exact gauge invariance to be able to factorize, and without factorization you cannot make physical sense of the whole construction build on the indefinite Hilbert space. But you are not at all obliged to start with some indefinite Hilbert space.
Of course, in the early days they completely fixed the gauge before quantizing. That's another equivalent way to quantize the em. fieeld, which is even preferrable if you learn the subject for the first time. It's only disadvantage is that it is not manifestly covariant, which makes calculations of higher-order perturbative corrections a nightmare.Sunil said:The original approach to QED did not use an indefinite Hilbert space. The references to the original approach:
Dirac P.A.M. (1927). The Quantum Theory of the Emission and Absorption of Radiation. Proc Roy Soc A114, 243-265
Fermi, E. (1932). Quantum Theory of Radiation. Rev Mod Phys 4(1), 87-132
But I would nonetheless recommend instead
Akhiezer, A.I., Berestetskii , V.B. (1965). Quantum Electrodynamics.
which give also the formulas for the original approach.
Nevertheless also there gauge invariance is needed to make physical sense of the theory. There's no way out: The math of the Poincare group tells you that a massless vector field must be a gauge field.
