I Producing enough force with a Solenoid
To create a solenoid that generates approximately 0.5 lbs of force, adjustments to the coil design are necessary. The current setup, using 34 AWG wire wrapped 9500 times at 32V, only lifted 32g, indicating the need for increased efficiency. Solenoids primarily attract metal objects and require a mechanism to convert this pull into push force, such as a non-conductive rod. It's important to calculate the resistance of the wire and ensure the voltage supply is adequate for the load. Understanding the magnetic field strength and amp-turns will also aid in optimizing the solenoid's performance.
PLA2820
TL;DR Summary
Hi,
This is not a homework problem, but a small personal project where I am looking to create a small solenoid that can create enough pushing force of approximately 0.5 lbs. I am wondering what the best route is to create this amount of force.
So far, I was able to lift about 32g with my first solenoid which was 34 AWG wire wrapped about 9500 times around a coil with a plastic insert thickness (between the armature and coil) of .045 inches and this was at 32V power supply. The cylinder armature is .25 inches in diameter and 1 inch long.
To generate a stronger force what are some changes I can make to my coil? I would ideally like to be able to use 9V to generate this force in the long run. I am not sure if I am missing any other information that would be helpful but please let me know, Thank you.
How about starting with something like this: https://engineering.icalculator.com/solenoid-coil-electromagnetic-force-calculator.html ?
You input the Length, Area, Number-of-Turns & Current for the coil and it calculates Force. You get voltage from the current by finding the total resistance of the turns of wire and using Ohm's law.
PLA2820 said:
TL;DR Summary: Producing enough force with a Solenoid
This is not a homework problem, but a small personal project where I am looking to create a small solenoid that can create enough pushing force of approximately 0.5 lbs. I am wondering what the best route is to create this of force.
Great reply by @renormalize so I can only add a couple small questions/points.
You mention a "push" requirement by your solenoid -- hopefully you see that solenoids attract metal slugs into their interior because of the magnetic field gradient. Solenoids cannot "push" unless you convert their pull into a push via a non-conductive back-pusher plastic rod. Does that make sense?
It's great that you've made an attractive solenoid, but it would be good if you could post the equations associated with your device. What was the resistance per unit length of your wire, and what current does that imply for the voltage you applied? Are you sure that your voltage source supplied that full source voltage to your load, or maybe did your load decrease the source voltage due to the source resistance?
What would you estimate your peak internal solenoid B-field to be given your source voltage and coil resistance and resulting number of amp-turns?
:smile:
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
