Product of Smooth Manifolds and Boundaries
The discussion revolves around the product of smooth manifolds and their boundaries, specifically addressing the case where M_1,...,M_k are smooth manifolds and N is a smooth manifold with a boundary. The key point is that M_1×...×M_k is smooth, allowing the use of charts to demonstrate that the product M_1×...×M_k×N also has a boundary. The approach involves using a coordinate chart for N that restricts one coordinate to non-negative values, indicating the presence of a boundary in the product manifold. Additionally, it emphasizes the need to show that product charts are smoothly compatible. This foundational understanding is crucial for solving differential topology problems related to manifold boundaries.
Arkuski
Sorry guys, I have some differential topology homework, and I may be asking a lot of questions in the next few days.
Problem Statement
Suppose M_1,...,M_k are smooth manifolds and N is a smooth manifold with boundary. Then M_1×..×M_k×N is a smooth manifold with a boundary.
Attempt
Since M_1,...,M_k are smooth manifolds, we are allowed to use the theorem that states that M_1×...×M_kis smooth with charts (U_1×...×U_k,\phi _1×...×\phi _k).
I get the idea that given the smooth manifold $N$ with coordinate chart (U,\psi _i) where \psi _i:N\rightarrow H^n (H^n is the half plane of dimension n), we show that H^n restricts x_i to non-negative values, and then the entire product in consideration will only have one coordinate restricted to non-negative values, signifying the presence of a boundary. I'm just really confused about how to put it into words.
Problem Statement
Attempt
The theorem you quoted shows that M_1 \times \cdots \times M_k is a smooth manifold, so it's sufficient to prove the result for M \times N, where M is an arbitrary smooth manifold.
Take an arbitrary point (x,y) \in M \times N. Then take a chart on M centered at x and a chart on N centered at y, work out what the codomain of the product chart is, and confirm that the chart is a homeomorphism.
Then you'll need to show that all product charts are smoothly compatible.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 20 ·
  • · Replies 36 ·
  • · Replies 39 ·
13K
