A Project img on X-Y surface to a cylinder placed in center....
Amirps
Hi ,
I came across a problem ,I've search a lot but couldn't exactly find the solution.
here is my problem:
suppose there is an image ( I call it IMG_A),place IMG_A in the X-Y plane , put a mirror cylinder at the center of IMG_A. what we see in the cylinder mirror is a deform image (I call it IMG_B) . what I try to achieve by this program is IMG_B.
I've already write a piece of code in Matlab using this equation
for i=1:IMG_A_Width
for j=1:IMG_A_Height
cy(i,j,1)=cyradius*cos(i*(2*pi/IMG_A_Width)) ;%cylinder X
cy(i,j,2)=cyradius*(sin(i*(2*pi/IMG_A_Width)));%cylinder Y
cy(i,j,3)=j*(cyHeight/IMG_A_Height) ;%cylinder Z
cy(i,j,4)=IMG_A(i,j);%cylinder image
end
end
but this is not exactly what I want ,this program just wrap the IMG_A around the cylinder. in other words the warping is in the horizontal direction.would you please be kind enough helping me to understand the equation I need to write this program?
Before you start writing code: how do you look into the mirror? That will influence the picture you see.
Try to solve the problem for some random viewing direction, by working against the direction of the light: where does your viewing direction hit the mirror? Where is the reflected viewing direction, and where does it hit the xy plane?
Fou
fortunately the viewing angel is constant and it is 30 degrees.
[the light will travel at the angel of 30 degrees from XY plane and hit the mirror ]
That sounds like a ray-tracing problem in computer graphics.
You want to think in terms of eye-rays and parametric coordinates with planes (your image) and cylinders (the deformed image)
You have the starting point (Vs) for each ray (where the eye is) and the direction (unit vector Vd) where that ray goes.
The first place that rays hits anything gives a parametric coordinate u. Each point and vector is three components (x,y,z)
R = Vs + u.Vd
A plane is defined as P = A.x + B.y + C.z + D = 0
A cylinder is defined as C = A.x^2 + B.y^2
You want to intersect your ray R with the cylinder, calculate the reflection vector of that ray, and where the reflected vector hits the plane.
Here's some reference material:
http://www.cl.cam.ac.uk/teaching/1999/AGraphHCI/SMAG/node2.html
Likes Amirps and mfb
I would just add to #4 that a natural way to do this is pixel by pixel. For each pixel, you want to know how to color it. Calculating where the ray from the eye through the center of the pixel, after being reflected by the cylinder, hits the plane — if it hits the plane at all — will determine what color the pixel should be. For more realism you might want to decrease the intensity of that color in proportion to the squared length of the entire light ray (i.e., from the eye to the cylinder to the plane).
Likes Amirps
Hello! There is a simple line in the textbook. If ##S## is a manifold, an injectively immersed submanifold ##M## of ##S## is embedded if and only if ##M## is locally closed in ##S##. Recall the definition. M is locally closed if for each point ##x\in M## there open ##U\subset S## such that ##M\cap U## is closed in ##U##. Embedding to injective immesion is simple. The opposite direction is hard. Suppose I have ##N## as source manifold and ##f:N\rightarrow S## is the injective...
