Project to detect open collector/ high impedance signals
To monitor an open collector alarm signal, using a pull-up resistor is recommended for proper signal detection. Connecting the signal to a computer's parallel port allows for easy monitoring and logging of alarms. There is a need for specific circuit designs and software solutions to facilitate this setup, especially to keep costs low compared to commercial options. While there are no regulatory concerns for this project, ensuring the correct pin assignments and software compatibility is crucial. Resources for schematics and software for interfacing TTL-level signals are widely available online.
dforde
I am trying to come up with a way to monitor a device that alarms. The signal is open collector: high impedance when not alarm. I would also like to be able to connect this to a computer and monitor and log the alarms when they happen. Any help would be greatly appreciated.
Use a pull-up resistor. You can connect a TTL-level signal through your computer's parallel port. (This is the easiest way, at least.)
- Warren
Thanks for the reply, do you know of an available circuit design for this, and the pin assignments for the port, also what kind of software could I use for the monitoring of the alarms, any and all help is greatly appreciated, the commercial solution to this is very $$$$$$.
I understand the desire to save money, but aren't there regulations governing alarm systems? In my experience, there are certain things that need to be done in a certain way, in order for a commercial building's insurance underwriter to approve of an alarm system.
This project is not for a building or anything like that, so there are no regulations involved, I have a number of alarm devices that when they alarm, there is a 3.5mm mono jack, tip is signal output, ring is 0V. Signal is open collector type: high impedance when not alarm, low. I want to be able to monitor the devices on a single computer, so I can log when they go off. Any help for a solution to this is appreciated, I am also trying to keep cost to a minimum. The pull-up resistor idea might work if I can get details on the setup, and appropriate software to monitor it.
Schematics (and software) for interfacing TTL-level signals are all over the web -- try using google to search for them. Use a 5V pull-up resistor, and you should be fine.
- Warren
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
