Projectile Launch Speed: Solve 876j Work Homework
  • Thread starter Thread starter Chica1975
    Projectiles Work
To find the launch speed of a projectile given 876 joules of work on a 0.398 kg projectile, the work-energy principle can be applied, stating that work done is equal to the change in kinetic energy (W = ΔE). The gravitational force acting on the projectile is approximately 3.9004 N. The user is struggling with the calculations and has attempted to draw a diagram to visualize the problem. They acknowledge that the work done translates entirely into kinetic energy. Further assistance is requested to solve for the launch speed.
Chica1975
A projectile launcher did 876j of work on a .398kg projectile what is the launch speed of the projectile?
W = f*d
mg = 3.9004
after that I am stuck
I drew a diagram and tried a few things but am completely stuck. please help.
The work done is entirely kinetic :wink:
thanks I will look it up and try again.
W = F * d is only a mathematical tool to calculate how much work is done. The applicable statement of physics is W = \DeltaE
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
