Projectile motion apple throw question
The discussion revolves around a physics problem involving projectile motion, where an apple is thrown from a height at an angle of 30 degrees. The horizontal distance covered by the apple is 12 meters, and the time taken for the apple thrown straight up to return is 1.6 seconds. Participants clarify that the time for the upward throw does not directly apply to the angled throw, as the velocities differ. To find the height below the friend, the initial speed of the apple must be calculated using the given range and time. The conversation emphasizes the need to determine the initial speed from the vertical throw to solve the problem accurately.
sniper_08
you have fallen into a hole in the ground. your friend throws an apple to you to keep you happy. you catch the apple 12.0 m from where your friend threw it. (basically range is 12 m). before throwing the apple to you, she threw it at the same speed directly up in the air, and it took 1.6 s to return to her had. how far below your friend are you?
since you guys can't see the diagram:
the angle above the horizontal is 30.
t = 1.6s
range or horizontal distance is 12 m
how do i find the height ( how many meters am i below the person on the cliff)
i don't know if i am doing it right how do find the height?
y = (Viy)(t) + 0.5(ay)(t)^2
range = Vix x t
Vix = 12 m / 1.6s = 7.5 m/s
Vix = cos30 x Vi
Vi = 7.5m/s / cos30 = 8.66 m/s
then Viy = sin 30 x 8.66m/s = 4.33 m/s
Why are you assuming that the time for your friend to toss the apple up and catch it is the same as the time it takes the apple to reach you? One velocity was directed straight up, the other is launched at an angle.
i don't undrstand?
ty = tx
It's your equation!
The 1.6 seconds was the time for your friend to toss the apple straight up and catch it on its return. What makes you think it applies to her tossing it down to you?
so how would you solve it?
I would first determine the speed at which she throws the apple (both times). The problem statement says that they are the same. So how would you go about determining that initial speed from her first toss?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
