Projectile Motion: Calculating Range, Maximum Height, Speed & Angle
The discussion focuses on solving a projectile motion problem involving a projectile fired into the air. The horizontal range and maximum height have been calculated as 56 m and 49 m, respectively. To determine the speed just before impact, the horizontal component of velocity remains constant at 8.8 m/s, while the vertical component can be found using kinematic equations. The final vertical velocity is influenced by gravitational acceleration, and the angle of motion before impact can be calculated using the tangent of the vertical and horizontal velocities. Understanding these components is essential for completing the calculations for speed and angle.
miley1234
Urgent! projectile motion
Heyy every1
Q Exactly 2.7s after a projectile is fired into the air from the ground ,it is observed to have a velocity v = (8.8i+4.5 j) m/s where the x-axis is horizontal and the y-axis is positive upward .
a)Determine the horizontal range of the projectile
b)Determine the maximum height above the ground
c)Determine the speed of motion just above the projectile strikes the ground .
d)Determine the angle of the motion just before the projectile strikes the ground .
I managed to do the first two parts where max height is 49m and range is 56 m .Bt i do not noe how to go abt the c) and d) part
What is horizontal component of the velocity? What is the vertical component of final velocity?
well i was able to calaculate the max height and range using horizontal velocity to be 8.8 and vertical final velocity as 4.5 at 2.7 s .This much information only was given n the question tht s why i m confused
For d), knowing the horizontal and vertical components of initial velocity should help you. You know that the trajectory is parabolic and so just prior to impact, use the condition,-v_{fy} \hat{y} = v_{oy} \hat{y}.
Horizontal velocity(i component) remains constant since no forces acting on it.
Vertically(j component) there is negative acceleration.
Sketch a graph of velocity vs. time. Upward as positive.
Δv/Δt is constant. You can find initial vertical velocity from acceleration equation.
Speed it the vector sum of vertical and horizontal velocity.
Angle of projection is just the tangent of vertical and horizontal velocity.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
