Projectile Motion Diver Jump Question
The diver's initial velocity was calculated using both the horizontal and vertical components of her motion. The horizontal component was determined as 5.06 m/s, while the vertical component was found to be 10.05 m/s. The total initial velocity was computed using the Pythagorean theorem, resulting in 11.25 m/s. However, the angle calculation using the arctangent function yielded an incorrect result. The discussion concluded with the realization that an error had been made, prompting further investigation into the calculations.
lvn
A diver springs upward from a board that is 3.60 m above the water. At the instant she contacts the water her speed is 13.1 m/s and her body makes an angle of 67.3 ° with respect to the horizontal surface of the water. Determine her initial velocity, both (a) magnitude and (b) direction.
Basically what I've tried is I found initial velocity component X by finding the final velocity X component:
Vx = Vox
Vx = 13.1cos67.3
Vox = 5.06m/sThen I found the initial velocity Y component through the kinematic equation:
Vy^2 = Voy^2 - 2a(y-yo)
Voy = sqrt(171.61 - 2(-9.8)(-3.6))
Voy = sqrt(171.61 - -19.6(-3.6))
Voy = sqrt(171.61 - 70.56)
Voy = sqrt(101.05)
Voy = 10.05m/s
Using pythagoras to find Vo:
Vo = sqrt(10.05^2 + 5.06^2)
Vo = sqrt(101.0025 + 25.6036)
Vo = 11.25m/s
Theta:
Tan^-1 (Voy/Vox)
= 96
Answer was wrong - what am I doing wrong?
Figured it out.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
