Projectile Motion (find theta)
The discussion revolves around determining the initial projection angle of a projectile given that its speed at maximum height is 0.31 times its speed at half maximum height. Participants suggest decomposing the velocity vector to analyze the components at different heights. The equations for height and range are referenced, and a ratio is proposed to relate the speeds at different heights. There is a focus on the significance of the horizontal velocity component being constant at maximum height. The conversation indicates that the user is seeking guidance on how to set up the problem correctly to find the angle.
bengavinb20
The speed of a projectile when it reaches its maximum height is 0.31 times its speed when it is at half its maximum height. What is the initial projection angle of the projectile?
h=(Vi^2 * sin^2 θ) / 2g
R=(Vi^2 * sin2θ) / g
I realize that i need to somehow come up with a ratio and set the two equal to each other. However, I'm having difficulty with the initial step. Maybe I could get a hint that could set me on the right track?
Decompose the velocity vector.
At the top which component of velocity is zero?
Use this idea to find the ratio. As you mentioned
So after decomposing the velocity vector I got:
Vi = -yf-at2 /t
Plugging that into the equation for h...
h= ((-yf-at2)2*(sin2θ)) / 2g
and then
0.5h = 0.31((-yf-at2)2*(sin2θ)) / 2g
Am I on the right track?
You see at the top point V is just Vx so can you relate this to the given information.
I'm sorry for late response I got lectures :)
So you still solving the problem?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
