Projectile Motion football pass
The discussion revolves around a physics problem involving projectile motion in a football pass scenario. The quarterback throws the ball at a speed of 26 m/s at a 60-degree angle, 2 seconds after the receiver starts running down the field. Key questions include determining the time of flight for the football and the average speed of the receiver. Participants suggest using standard constant acceleration equations to solve for the time the ball is in the air. The conversation emphasizes the need for guidance in applying the projectile motion formulas to find the required values.
DJey
Just started this course, please bare with me, I am not sure what to do, blanked out
Question: A football quarterback attempts a pass to one of the receivers. As the ball is snapped, the receiver leaves the line of scrimmage and runs directly down the field. the quarterback releases the ball 2.0s later and from a position 3.0m behind the line of scrimmage. he throws the ball at a speed of 26m/s at and elevation of 60 degrees above the horizontal. The receiver makes a diving reception, catching the ball just as it reaches the ground.
a) What is the time of flight of the football?
b)what is the average speed of the receiver ?
Welcome to PF!
Hi DJey! Welcome to PF! :wink:
DJey said:
… please bare with me …
uhh? it's not that sort of forum! :redface:
Use the standard constant acceleration equations …
show us what you get :smile:
thanks alot,
i know when i said please bare with me i really meant guide me through,
You need to find out the time elapsed from the time the ball was thrown until it landed. Using the projectile formula for y, one can solve for t for the time it left until it landed.
y=(Vi)sin(angle)t-1/2gt^2
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
