Projectile Motion - formula derivation
The discussion focuses on deriving the kinetic energy formula K = ½ x mgsH for an arrow after release from a bow, where m is mass, g is gravitational acceleration, and sH is horizontal velocity. The user initially confused the derivation with a related formula involving horizontal displacement, r = v^2 sin(2θ)/g. They seek clarification on how to isolate components of velocity in the derivation process. The conversation emphasizes the need for a formal derivation that connects the kinetic energy formula to the projectile motion equations. Understanding these relationships is crucial for improving their grade on this bonus question.
arpita45
present a formal derivation of the formula (given above) that was used to calculate the kinetic energy of the arrow immediately after release from the bow.. repeated here:
K = ½ x mgsH
Where m is mass, g is grav. acceleration and sH is horizontal velocity.
My mistake was that I found the derivation of the clue and not the equation above.
clue : The above formula is derived from v^2 x sin 2 theta/g.
This formula is used for horizontal displacement, giving us sH = v^2 sin 2 theta. The problem is how do I get rid of the component of velocity?
I`m not sure if this is correct but here it goes...
If we make sin theta independent then - sin (theta) = 2v^2/g
Now bring g to the other side, we get, sin(theta)x g = 2v^2
Now to make v^2 independent by bringing 2 to the other side, we get
g x sin (theta) /2
This is a bonus question, and if i can get this right I might be able to improve my grade. Please Help
You have said that the clue is that the formula is derived from
v^2 x sin 2 theta/g
I assume this means v^2 \cdot \frac{sin(2\theta)}{g}?
Also, a statement of the actual question would be very helpful.
The range of a projectile is given by r = \frac{v_0^2\sin(2\theta)}{g}. (r \equiv s_h here.)
Could you post the exact wording of the question?
K = ½ x mgsH
This is the exact wording of the question. Hope it helps, also r = sh.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
