Projectile Motion- Object Launched in the Air
A spring toy is launched at 2.3 m/s at a 78° angle, reaching a maximum height of 0.26 meters. The vertical component of the initial velocity is calculated as 2.25 m/s, and the total time of flight is determined to be 0.46 seconds. The maximum height is derived using kinematic equations, specifically focusing on vertical motion. There is a suggestion to use a different SUVAT formula that does not require time to find the height directly. The discussion emphasizes the importance of rounding correctly and following textbook methods while also considering alternative approaches.
Catchingupquickly
A spring toy is launched from the ground at 2.3 m/s at an angle of 78° to the ground.
What is the maximum height reached by the spring toy?
## \vec v_1v = \vec v_1 sin\Theta##
## \Delta \vec d = \vec v_1v \Delta t + \frac 1 2 \vec a \Delta t^2##
## \vec v_1v = 2.3 m/s [up] (sin78 degrees)
\\ = 2.25 m/s [up]##
## \Delta \vec d = \vec v_v1 \Delta t + \frac 1 2 \vec a \Delta t^2
\\ 0 = (2.25 m/s [up]) \Delta t + \frac 1 2 (-9.8 m/s^2) \Delta t^2
\\ 0 = \Delta t (2.25 m/s - 4.9 m/s^2) \Delta t
\\ \Delta t = 0.46 seconds##
That's the total time it was airborne. Maximum height is half that so 0.46/2 = 0.23 s.
Now to find the height.
## \Delta \vec v = \vec v_1 \Delta t + \frac 1 2 \vec a \Delta t^2
\\ = (2.25 m/s) (0.23 s) + \frac 1 2 (-9.8 m/s^2) (0.23)^2
\\ = 0.52 - 0.26
\\= 0.26 m [up]##
The max height is 0.26 meters [up].
I've followed my textbook's lead of rounding to two significant places through the work.
Am I correct at all?
Everything looks good to me. Personally, I keep the intermediate answers, in my calculator, to full digits, then round at the end.
Thank you. Yeah, overall, the textbook isn't the greatest, but I'm just following its lead for this course.
You were not asked for the time. You can get to the height directly by using the right SUVAT formula. Which one does not involve time?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
