Projectile Motion Problem with stunt driver
The discussion revolves around a stunt driver needing to calculate the speed and distance required to successfully land on a soft pad after jumping off a 30m cliff. For part (A), the driver must reach a horizontal speed of 36.8 m/s to land on the pad located 90m away, calculated using projectile motion equations. In part (B), considering an acceleration of 5 m/s², the driver needs to build up the required speed before jumping, which requires a distance of approximately 135.42 meters to reach the necessary velocity. The calculations confirm that the time in the air does not affect the distance needed to accelerate to the required speed. Overall, the analysis highlights the importance of both speed and distance in achieving a successful stunt.
orbits
Stunt driver hired to do a scene where a motorcycle speeds horizontally off a 30m high cliff. There's a soft landing pad located 90m from the base. Ignore air resistance. (A) How fast must he go land on the soft padding? (B) the motorcycle has an acceleration of 5 m/s^2 on a dry road surface, he needs a certain distance from the edge to build up required speed. What is the distance?
My attempt: (A) Y= Yo + Vxo(T) + 1/2 (g) (T^2) ---> 0= 30 + 0 + (-5) T^2 --->T=sq.rt 6 ---> T=2.44s (we use 10 instead of 9.8)
Xf= Xo + Vxo(T) + 1/2 (Ax) T^2 ---> 90=0 + Vxo (2.44) +0 ---> Vxo = 36.8 m/s
(B) X=Xo+VxoT + 1/2 (Ax)T ---> X-Xo= (36.8)(2.44) +0 ---> Displacement = 89.8 m
Did I do this correct?
Question is asking "build up required speed" ... So what distance he needs to come with horizontal velocity component of 36.8 m/s (which looks good) if he has acc of 5 m/s^2 ... That is before he jumps so the time he is in the air has nothing to do here.
So would I use:
(Vf)^2 = (Vxo)^2 + 2(Ax) (Displacement)
0-36.8^2 = 10 (Displacement)
1354.24/10 = Displacement = 135.42 m
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
