Projectile Motion Problem with thrown ball off roof
A ball is thrown from a roof at a height h, hitting the ground 1.50 seconds later at a distance of 25.0 meters and an angle of 60 degrees with the horizontal. The problem requires finding the height h, the magnitude of the initial velocity, and the angle of projection. Initial calculations led to confusion regarding the correct use of projectile motion equations and the direction of acceleration. Clarifications from other users emphasized the importance of correctly identifying the angle in the equations and the sign conventions for acceleration. Ultimately, the discussion helped the original poster realize their misunderstanding of the equations, leading to a breakthrough in solving the problem.
coco87
A ball is thrown leftward from the left edge of the roof, at height h above the ground. The ball hits
the ground 1.50s later, at distance d=25.0m from the building and at angle \theta =60^<br /> <br /> {\circ} with the horizontal. (a) Find h. What are the (b) Magnitude and (c) angle relative to the horizontal
of the velocity at which the ball is thrown? (d) Is the angle above or below the horizontal?
http://lcphr3ak.is-a-geek.com/fig49.png
d=25.0m
\theta=60^{\circ}
The answers in the back are:
a)32.3m
b)21.9\frac{m}{s}
c)40.4^{\circ}
d)below
x - x_{\circ} = v_{\circ} t - \frac{1}{2} a t^2
v_{\circ x} = v_{\circ} \cos{\theta _{\circ}}
v_{\circ y} = v_{\circ} \sin{\theta _{\circ}}
I'm missing an observation here, because I don't see enough information to solve this. This problem is suppose to
be solved with projectile motion. So first I attempt to find v_{fx} (which is the x component
of the vector at \theta): x - x_{\circ} = v_{fx} t - \frac{1}{2} a t^2 which is -25 = <br /> <br /> v_{fx} (1.50). This gives me v_{fx} = -16.667. Using this, I take v_{fx} = v_f \cos{\theta}<br /> <br />, which is: -16.667 = v_f \cos{60}, so v_f = -33.32. Using this, I find v_{fy}<br /> <br /> by taking v_{fy} = v_f \sin{\theta} and doing v_{fy} = (-33.32)\sin{60} so v_{fy} <br /> <br /> = -28.856. So, to find h, we solve for y. y = v_{fy} t - \frac{1}{2} a t^2
becomes y = (-28.856)(1.50) - \frac{1}{2} (9.8) (1.50)^2 which says y = -54.309. Now, the
absolute value of y should be the height, but this is waaaaay off from the answer. I'm practically out of
ideas.
Could anyone explain what I'm doing wrong? If I didn't provide enough info, just let me know and I'll try to
provide more.
Thanks!
Hi coco87! :smile:
(have a theta: θ :wink:)
coco87 said:
… Using this, I take v_{fx} = v_f \cos{\theta}<br /> <br />, which is: -16.667 = v_f \cos{60}, so v_f = -33.32. Using this, I find v_{fy}<br /> <br /> by taking v_{fy} = v_f \sin{\theta} and doing v_{fy} = (-33.32)\sin{60} so v_{fy} <br /> <br /> = -28.856.…
Nooo … θ in your formula is the angle at the roof. not the θ (= 60º) in the diagram! :smile:
Take care with the sign of the acceleration.
It is often helpful to write down on your diagram which direction you are taking as positive.
tiny-tim said:
Hi coco87! :smile:
So, I'm either using the wrong formula, or I need to find the initial velocity (or angle)? I don't know of any other formulas (other than v = v_{\circ}+at), and I have no idea how I would even obtain the angle up there. Could you possibly give me a hint? (or another one :wink: )
Thanks for the responce!
you can use that formula to find the initial vertical velocity. Then you can work out an angle!
What you had said triggered an idea, and after playing around with the equations, I found out that I had misunderstood the Constant Accelloration equations all along.. well, I do now :biggrin:
Thank you guys for your help!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
