Projectile motion - velocity and distance
A projectile is launched at 60 m/s at a 30-degree angle and lands on a hillside after 4 seconds, with air friction neglected. The key questions are the velocity at the highest point and the straight-line distance to the target. The calculated distance is 207 m, but the textbook states it should be 212 m. The user attempted to solve the problem by breaking down the velocity into x and y components and applying kinematic equations, but their calculations for both the final velocity and distance appear to be incorrect. Clarification on the calculations and a step-by-step breakdown of the work is requested for better assistance.
piknless
Projectile motion -- velocity and distance
A projectile is launched with an initial speed of 60 m/s at an angle of 30 degrees above the horizontal. The projectile lands on a hillside 4 seconds later. Neglect air friction. What is the projectile's velocity at the highest point of it's trajectory? What is the straight line distance from where the projectile launched to where it hits it's target?
x=vt
For my B I got 207 m but the answer in the book says 212 m.
x=vt
Can you please show us your work step-by-step? That will make it easier to help you.
Also, I will add a bit to your one-word thread title -- please try to make your thread titles very descriptive of the specific question you are asking in the thread.
I'm not exactly sure how to use symbols, but my work is as follows. First I split the vector into the x and y components. I got the vector component x to be 51.961523423 and the vector y component to be 30. The I used the formula: final velocity squared equals initial velocity squared plus 2 times change in y time acceleration. The initial velocity is 30 m/s. The change in y is 2 times velocity times 1/2 time plus acceleration times 1/2 times time squared. I get the cahnge in y to be 40.4 I got the final velocity to equal 10.4. That is incorrect. For part b I used x=vt velocity is 51.96152423 and the time is 4 seconds. multiplied I get 207.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
