Prolonging the Life of Poorly Accessible Rusted Steel
  • Thread starter Thread starter scott123
    Life Steel
A rear 3/16" OD steel brake line failure due to rust prompted a discussion on temporary repair solutions. The user spliced the damaged section with copper nickel line but noticed bubbling paint near the engine, indicating potential rust. Given limited access for repairs and a short-term ownership of the car, the user seeks effective methods to mitigate rust for a few months. Suggestions include using tannic acid or zinc paint, as well as commercial rust-stopping products that don't require repainting. The conversation also highlights the importance of fresh brake fluid in slowing corrosion and discusses various rust removal options, emphasizing the use of gentler acids like phosphoric acid, lemon juice, or vinegar to avoid excessive metal loss. The user is advised to consider both liquid and gel rust removers based on the specific application.
scott123
I had a rear 3/16" OD steel brake line in my car fail due to rust. I spliced out the area with the hole with copper nickel line, but, I noticed that there's areas closer to the engine where the painted surfaces have bubbled a bit. Unfortunately, access is such that I can't splice fresh line, but I can get a hand up there, and, to a point, maybe sand down the surface and paint it. Due to the gauge of the tubing, though, I can't sand that aggressively, so, no matter what, I can't remove every bit of rust.
I have a very old car that I don't plan on keeping more than a few months. I'm just trying to find an approach that buys me the most time. Right now, I'm thinking maybe tannic acid and then rustoleum. Or maybe zinc paint? Thoughts?
Accessing the lines involves both a window of good weather and a pretty hefty chunk of time lifting the car high enough and removing the protective shield, so whatever I come up with needs to be a one shot deal. Again, not looking for forever, just a few months. There's a good chance, that, doing nothing, I'll be fine for a few months, but, I'd still like to hedge my bets by trying something.
And, just to be clear, there's no need for a safety lecture. When my rear brake line failed, the car still stopped fine. If this were a front brake, I'd be a lot more cautious about slightly rusty lines, but, it's not. My front brakes are flawless.
Chemistry news on Phys.org
Rust may be working its way out, since brake fluid is highly hygroscopic.
Also, when one branch fails, most cars lose pressure in one front brake and the opposite rear brake (rather than both front or both rear calipers).
There are commercial products that stop the rust without the need for over-painting the affected surface.
Interesting. Regarding the hygroscopicity. So, potential water in the previously aging fluid might have been contributory. Assuming the corrosion was internal, now that the fluid has been aggressively replaced with fresh fluid, that might slow the corrosion down, correct?
What commercial products are you referring to?
Yes, fresh fluid will greatly help.
It seems that your tube is suffering a pitting corrosion.
If so, many more pin-holes are currently developing.
Please, see:
https://corrosion-doctors.org/Corrosion-History/Rusting.htm
You can look up "Rust remover jelly" for local options.
Loctite has good products.
Slightly off-topic for your brake lines, but here goes:
Generally, any acid will remove rust. Check the label on some of them, many are phosphoric acid which is a decent medium-strength rust remover.
Don't use strong acids like hydrochloric (muriatic) or sulfuric acid, they strip off so much of the metal surface that the rust returns with a vengeance.
For gentler action, there is lemon juice or vinegar.
You also have a choice of liquids or gels. Gels are great for larger items that you don't want to dunk in a large container. For smaller and/or more detailed objects I lean towards immersing in the liquid formulations; or sometimes saturating a rag and just wiping the surface.
Cheers,
Tom
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
