Proof of 2v Velocity When Gun Fired Aboard Plane
  • Thread starter Thread starter eddie
    Bullet Gun
When a gun fires a bullet at velocity v aboard a plane also traveling at velocity v, the bullet's new velocity can be understood through Newton's Laws of motion and Galilean transformation principles. The bullet's velocity relative to an observer on the ground is the sum of the plane's velocity and the bullet's initial velocity, resulting in a total velocity of 2v. This explanation holds true under the condition that the velocities involved are much less than the speed of light (v << c). The discussion emphasizes the simplicity of this proof using classical mechanics. Understanding these principles is essential for analyzing motion in different reference frames.
eddie
If a gun fires a bullet at a velocity v and is then taken aboard a plane traveling at a velocity v and is fired again in the direction of travel ,what is the simplest proof that the bullet's new velocity is now 2v ?
Newton's laws are invariant under a Galilean transformation.
Assume that this is a case where by sheer coincidence, two sources of coherent single-frequency EM wave pulses with equal duration are both fired in opposing directions, with both carrying the same frequency and amplitude and orientation. These two waves meet head-on while moving in opposing directions, and their phases are precisely offset by 180 degrees so that each trough of one wave meets with the crest of the other. This should be true for both the electric and magnetic components of...
