Proof that the world is not flat
In summary, Zee explains that by using the distances between four points on a flat piece of paper, one can deduce that the world is not flat. This is because the distances between four points cannot be accurately represented on a flat surface, indicating that the Earth's surface is not a Euclidean plane. This is further supported by calculations that show the disagreement between the total area of the triangles formed and the area of the quadrilateral formed, suggesting that the cities discussed are not coplanar.
  • #36
Vanadium 50 said:
Now, how many numbers do you have? Between 4 cities you have (4 x 3)/2 = 6 distances. So in principle you have enough information. I think you also do in practice, provided the 4 points are convex.
I'm not seeing how 4 non-coplanar points in [Euclidean] 3-space can fail to be convex; or that there are any 4 non-coplanar points in 3-space that you can't embed in a 2-sphere of unique radius.
Mathematics news on Phys.org
  • #37
Like a chevron.
  • #38
Vanadium 50 said:
Like a chevron.
But if it is only 4 points, when you add all the sides it still makes a convex tetrahedron.
  • #39
There is one problem with my post #30. The logic and conclusions are all fine, but the formula referenced is not actually what we want. The distances used in the formula based on the Cayley-Menger determinant would be the 'through the earth' distances, which are not the ones we want to use. These can be converted in terms of the radius we seek, and you have a complex implicit formula for radius (it being on both sides of the equation). Most likely, it is not solvable in closed form, but could readily be solved numerically.
  • #40
If the Earth is flat, then why has nobody ever taken a picture of the edge?
I don't get it. Are there really people out there who honestly believe the Earth is flat?
  • #41
I think it is more of an abstract exercise in proving it, sort of assuming you are arguing with someone who legitimately believes it.
  • #42
Also, in terms of motivation of the original source (differential geometry lite for physicists) discussing the minimum quasi-local geometric information needed to distinguish curvature, particularly the idea pure metric (distance) quantities are enough (if you allow angle measurements, you need fewer points).
The answer is you need pairwise distances between 4 points to detect curvature of a two manifold, and 5 points for a 3 manifold. Then we had a further discussion of whether pairwise distances between 4-points allows determination of the radius of curvature of a 2-manifold on the assumption that curvature is constant. I believe I have clearly demonstrated that this is so.
Likes WWGD
  • #43
One more note on the idea of using only distances rather than angles is that in GR, the notion of rigid grids whose angles you can measure is highly problematic; even angles between light rays is non-trivial in the presence curvature. This motivated Synge's purely metric approach; the real subtlety of his argument is going from observations about curvature of Riemannian 3-manifolds from 5 points to measuring curvature of a Lorentzian 4-manifold using only round trip times times between 5 world lines; this relies on a whole series of earlier results in the book on Fermi-Walker transport, and it is very surprising (to me) that it is sufficient.
  • #44
Hmm... good gravimeters can measure g with a precision of 10-9. Let them measure the horizontal component along the line of a laser, and you should get visible deviations within a meter. They can also measure how g decreases with height - again, a meter difference is sufficient. A measurement of the radius of Earth to ~1%, done in a lab, if you know the mass distribution of the lab itself with sufficient precision to account for its effect.
  • #45
But a gravimeter is providing direct information about curvature by a different means. So, having determined this, you then measure that it has predictable effects on light paths. That is interesting, but not the same as, e.g. making a series of measurements of angles between light rays and trying to deduce geometry from that. E.g. the idea that you can use sum of angles of triangle, when your triangle consists of light rays following null geodesics of unknown geometry, is an extremely non-trivial undertaking.
  • #46
Well, there is no GR solution that would make sense with a flat Earth, but I think if you trust GR then you see enough proofs of a round Earth anyway.
The gravimeters are a GR-independent way to see that the Earth is not flat (at least not relative to a light path).
  • #47
On further thought, I think you are not measuring curvature at all this way. The aim is to detect curvature over the 'lab size'. Curvature is divergence from SR spacetime. Change in g over the lab size has only a second order difference from the Rindler flat spacetime prediction. My understanding is that this difference has never been measured on Earth (at lab scale). [edit: Tides, of course, measure curvature over Earth as a whole. ]
Validating GR and measuring a direct 4-geometric affect of curvature are different endeavors.
  • #48
I never said you would measure curvature of spacetime. You measure an inhomogeneous gravitational field.
  • #49
I think further discussion of space-time curvature measurement should be in another thread, as it is physics of GR. This thread should stay on the original topic of geometric measurement of curvature within Riemannian manifold, specifically the case of a 2-surface.
  • #50
Whitehole said:
Yeah I got it but what does he exactly mean by saying "you can't extend the triangle to a planar quadrangle"? What does it have to do with the measurement mismatch?
Hi Whitehole
I don't think anyone actually got around to giving you the answer to your specific question. What he means is if you only use 3 cities and make triangles, then you'll never see a problem; you can take a hundred cities and draw a hundred different "planar triangles" (i.e. triangles on a flat piece of paper) and the Earth's curvature will not "show up"; the curvature will simply "get lost" as each triangle will have a small error in each of its angles that makes up for the "lost" curvature as you translate the triangles from the curved Earth onto the flat planar surface of your paper.
However, if you then go back and add a forth city onto each of your planar triangles - extending each triangle into a planar quadrangle, you'll see the curvature problem come into play - if your original triangle was Paris, Berlin, Barcelona (as in the example you used), then you'll not be able to find a single point for the fourth corner that is the correct distance away from all these three cities to Rome.
  • #51
Isn't it a lot easier? How can we have day and night at the same time in different places if Earth was flat?
Likes WWGD and mfb
  • #52
Big squares blocking the Sun? Gravity bending the Sun's rays so they hit they Earth before they get to the nighttime region?
  • #53
mgkii said:
Hi Whitehole
It is interesting how we reach this "breakaway" value of 4 , the least number of points needed to determine whether there is non-trivial curvature. Is there a name for this least value needed?
  • #54
But how do we then switch from night to day in the dark region?
  • #55
The Sun gets teleported back to its starting point? (Once the Earth is flat, anything is fair game.)
  • #56
Just throwing a thought on this; I could well be wrong, but I think you might need to think of this from a different starting point. Moving from a 3 dimensional Earth to a 2 dimensional plane by ignoring angles of the triangle is a form of dimensional reduction. You may be able to maintained angles by choosing a different form of reduction, and find a different type of breakaway - i.e. the value of 4 may simply be a feature of the chosen reduction.
Likes WWGD
  • #57
I don't know if there is a name, but the theory can be seen as follows:
You hypothesize your manifold is flat, and is embedded in a flat manifold of one higher dimension. Then, ask what is the fewest points in the higher dimensional flat manifold to make a simplex (polytope) with volume. For 2 space it is 3, 3-space it is 4, for 4-space, it is 5, etc. Then, consider e.g. 4 points in the two manifold. They would form a degenerate zero volume simplex in the embedding 3-space. This means that some expression of pairwise lengths (e.g. the Cayley-Menger determinant) that is monotonically related to simplex volume, must be zero, and this gives a criterion for flatness of the two manifold. Summary: the number of points needed determine flatness (purely by distance measures) is the minimum number to form a simplex in one higher dimension.
Likes WWGD and mgkii
  • #58
This is correct. It has already been pointed out earlier in the thread that you need fewer points if include angle measurements.
  • #59
Dr. Courtney said:
To me, this is the most convincing proof not only that the Earth is not flat, but that it rotates as explained in the rotating spheroid model.
For me, it is more convincing, because it can be done in a single room and does not depend on outside sources of data that may be less reliable.
If that's not a slam dunk, the repeating the experiment at several latitudes should be.
Nice. I think you've hit on the weakness in all the comments I've read so far. Namely, what do we mean by 'distance'? How would one know the 'distance'? By definition, the metric applicable to the Earth's surface is the contour length the great circle connecting any two cities. But this is a non-Euclidean geometry, a spherical geometry. (For one thing, the angles of a spherical triangle do not add up to 180 deg, which may play a role in our problem.) Therefore, the inconsistency between the distances defined by the spherical metric and the Euclidean distances is the result of the naive isomorphism between the 2 geometries. Perhaps there is a projection of the sphere onto the plane which preserves the distances between points on the two surfaces and the angles of triangles. I wouldn't know. But I do know what any 6th grader knows - that the Mercator projection is not the right one - all that business about Greenland being bigger than South America and so forth.
  • #60
Maybe one can somehow generalize the fact that any projection will produce distortions of some sort to make a general argument on the inequality/inequivalence between Euclidean and Spherical.
  • #61
There is a physical notion of distance which implements the mathematical notion, and abstracts from any knowledge of the geometry (metric). Then it is valid to ask whether how a set of such measurements can give you information about the geometry.
The physical notion is: take an ideal chain, fix it in e.g. Paris, extend it to Berlin, pull on it till it has no slack, then pull it to one place and measure it. The pulling till no slack implements the definition of geodesic as a distance minimizer.
  • #62
Yes, there was a recent news item about a rapper who was a flat-earther. In my lifetime, there was a prime minister of South Africa who believed in a flat earth. "It certainly looks flat to me!" he is quoted as saying. I surmise he was a fundamentalist with little use for books other than the Bible...
Likes Whitehole
  • #63
This thread seems to be taking on a life of its own, or am I imagining that?. Its interesting to see serious people discussing such an off the wall fringe notion. I sense a little entertainment value here. :doh:
  • #64
mgkii said:
Hi Whitehole
Hi mgkii, thanks for your explanation. You've got a point in your first statement, haha. Their explanation kinda pointed out what you are saying and I know what they mean but I wanted to understand what Zee is saying. I know this topic can be explained in a lot of ways but your explanation exactly answered my question. Thanks for clearing it up!
  • #65
Closing the loop on the original geometric aspects of the problem, I decided to program the method in equation (3) of the reference I gave in my post #30, dealing numerically with the complication described in my post #38. Surprisingly little code was needed (about 45 lines at the level of C, with no use of libraries for determinants or numeric solvers - I programmed those out in direct arithmetic for the specific case at hand, since the matrices are special, with lots of simplifications and a complete factorization is given for one of them in the reference). The expression we sought a root of was so unwieldy (when the arc to chord adjustment is included) that I didn't trust any fancy methods and just coded brute force binary interpolation given root bracketing.
One comment on my discussion with Vanadium 50 on convexity: a tight argument that there is no such thing as non-convex tetrahedron in 3-space. Take any 3 non-colinear points. They form a triangle. Take any 4th point non-coplanar, and the result is a convex tetrahedron. Whether the points embedded in 2-sphere form a convex polygon or not is irrelevant. As concrete demonstration, one of the two solved examples below shows solution for the radius from pairwise distances between cities that form a large chevron on the Earth's surface.
1) Paris, Berlin, Barcelona, Rome using pairwise distances mentioned earlier (P-Be, P-Ba,P-R,Be-Ba,Be-R,Ba-R) = (546,515.2,689,931,735.535.5)
The first thing I was curious about was how much the last pairwise distance would have to change to be compatible with a plane. The code described above includes a solver for this (as well as the radius problem). The not very surprising answer (since the longest distance is < 4% of circumference, so we are still near flat) is if you change 535.5. to 537.74, the distances become compatible with flatness. Given this, and the low precision of the inputs, I was expecting the worst for solving for the radius. I was pleasantly surprised to get 3871 for the radius from these number - not very far off at all.
2) Paris, Berlin, Boston, Cuzco (Peru). These form a concave polygon (in any connection order) on the Earth's surface. With the same convention for giving distances for a list points as above, the distances are: (546,3445,6225,3788,6760,3843). These also span a much bigger area. Not surprisingly, the last distance would have to shift to be 4360 for these to be compatible with flatness. The radius computed from these inputs is 3994, not bad given the limited precision of the inputs - benefiting from the much greater significance of curvature. (correct figure is average Earth radius of 3957).
Thus you can unambiguously compute radius from pairwise distances of 4 points on the sphere, and there is no requirement for convexity of the on sphere polygon.
If anyone is curious about other cases, it now just takes typing in the distances to solve.
  • #66
I would like to suggest a thought that might well be considered to be only a nit.
The use the distances between six pairs of cities (using four cities) to PROVE that the Earth is not flat ignores that the practical measurement of these six distances seems to require prior knowledge (e.g., GPS technology) that the Earth is not flat.
Regards,
Buzz
  • #67
You can use a (very long) ruler or comparable devices. That's how length measurements were done before GPS was set up. Triangulation helps as well, but there assuming a flat Earth will lead to trouble already (see the multiple angle measurements).
  • #68
Regards,
Buzz
No, following a straightest possible path locally, where difference from flatness cannot be discerned, is completely well defined and can, in principle, be carried out over any distance. All definitions of intrinsic curvature assume you can perform a variety of operations based on local asymptotic flatness without any apriori knowledge of curvature. For example, in principle, if radar distance between 5 objects in some some non-coplanar configuration were done on earth, and all the pairwise distnances were put in the order 4 Cayley-Menger determinant, the result would not vanish, indicating curvature of our universe. Of course, the precision required for this is unattainable in practice for a laboratory sized device (about one part in 10^30).
Anyway, the OP raised a purely geometric question - they wanted to know how distances between between 4 points could be inconsistent with flatness, as stated in Zee's text.
  • #69
Hi Paul:
My admitted nit was intended to raise a question about practicality, rather than what might be doable in principle. If the four cities were too close together, then the distance measurements would perhaps be consistent with flatness. If the cities were far enough apart for the measurements to reveal the non-flatness, then would radar technology be a practical means of measurement?
I am curious whether any current technology not dependent on prior knowledge of non-flatness would be practical to make the six measurements to show non-flatness.
Regards,
Buzz
  • #70
Buzz Bloom said:
Hi Paul:
Regards,
Buzz
Practical measurements, probably not. I would say the biggest practical difficulty on Earth (rather than a mathematical surface) is lack of local flatness. Even building roads, you always find the need to go around and up and down because of obstacles. But if you could build roads that are everywhere locally flat and straight, then measure them with an odometer, you could get enough precision. The thing is, we don't really live in a 2-manifold; the geometry problem is really answering questions about measurements within a 2-manifold.
Likes Buzz Bloom
