Prosthetic Limbs: Moving & Feeling Like Real - NOVA TV
  • Thread starter Thread starter dlgoff
The NOVA TV program highlights a groundbreaking amputation technique that enables prosthetic limbs to mimic the movement and sensation of real limbs. The documentary features advanced electronics that interface directly with nerves, showcasing significant technological advancements in prosthetics. The first half of the program focuses on the emotional aspects surrounding the research, while the technical details emerge around the 40-minute mark. Viewers express a desire for more in-depth technical information. Overall, the documentary is recognized as a significant achievement in the evolving field of prosthetics.
dlgoff
TL;DR Summary
PBS television program
The NOVA TV program description was: A new amputation technique allows prosthetic limbs to move and feel like the real thing. What amazed me was the electronics that interfaced with the nerves.
Likes sysprog, Tom.G and berkeman
Direct link is:
https://www.pbs.org/wgbh/nova/video/augmented/
Rather interesting documentary. About 1.4 hours long.
The first 30 minutes or so are leading up to the event that triggered the research; it tends to play on the emotions rather heavily though.
The technical aspects start around the 40 minute mark. As a technologist, I would have appreciated a bit more detail.
Overall, quite a technological accomplishment... and the field is just getting started.
Thanks @dlgoff !
Cheers,
Tom
Tom.G said:
Thanks @dlgoff !
My pleasure Tom. And thanks for the direct link.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
