Proton moving in magnetic field
A proton traveling in the +z direction at 4105 m/s is subjected to a magnetic field of 0.25 T in the +x direction. The force on the proton can be determined using the equation F = qvB, where q is the charge of the proton, v is its velocity, and B is the magnetic field strength. The right-hand rule helps establish the direction of the force, which is perpendicular to both the velocity and the magnetic field. Confusion arises regarding the application of the left-hand rule, but the correct approach is to consistently use the right-hand rule for protons. Ultimately, the discussion emphasizes the importance of correctly applying these rules to find both the direction and magnitude of the force on the proton.
sdevoe
At a particular instant a proton is traveling in the +z direction, with speed 4105 m/s. At the location of the proton there is a magnetic field of magnitude 0.25 T in the +x direction, due to current running in a nearby coil.
what is the direction and magnitude of force on the proton?
none i think?
Do you use the right hand rule possibly?
The right hand rule can give you the direction of the force, but not the magnitude.
What equation do you know that gives the force on a charged particle of charge q moving with velocity v in a magnetic field of strength B?
Try to find out the formula for the force on a charged particle in a magnetic field. The direction of the field is given by the left hand rule.
the equation is F=qvB but then using the left hand rule since it is a proton would give me negative y direction if I'm not mistaken and that is incorrect?
You can use either right handed screw rule or Flemming's left hand rule.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
