MHB Prove a quartic equation ax^4+bx^3+cx^2+dx+e=0 has at least one real solution
  • Thread starter Thread starter anemone
If the quadratic equation ax^2+(c-b)x+e-d=0 has real solutions greater than 1, it can be shown that the quartic equation ax^4+bx^3+cx^2+dx+e=0 has at least one real solution. By defining f(x) = ax^4+bx^3+cx^2+dx+e and evaluating it at ±√s, where s is a solution of the quadratic, it is established that f(√s) and f(-√s) yield opposite signs if bs+d ≠ 0. This leads to the conclusion that, by the intermediate value theorem, there must be at least one real root for the quartic equation between -√s and √s. Thus, the existence of a real solution for the quartic equation is guaranteed.
anemone
MHB
POTW Director
If the equation $ax^2+(c-b)x+e-d=0$ has real solutions that are greater than 1, prove that the equation $ax^4+bx^3+cx^2+dx+e=0$ has at least one real solution.
Mathematics news on Phys.org
[sp]Let $s$ be a solution of $ax^2+(c-b)x+e-d=0$ with $s>1$. Then $as^2 + cs + e = bs+d.$
Let $f(x) = ax^4+bx^3+cx^2+dx+e$. Then $f(\sqrt s) = as^2 + cs + e + \sqrt s(bs+d) = (bs+d)(1 + \sqrt s).$ In the same way, $f(-\sqrt s) = (bs+d)(1- \sqrt s).$
If $bs+d = 0$ then $\sqrt s$ and $ - \sqrt s$ are zeros of $f(x)$. If $bs+d \ne 0$ then $f(\sqrt s)$ and $f(-\sqrt s)$ have opposite signs (because $\sqrt s > 1$). So by the intermediate value theorem $f(x)$ must take the value zero somewhere between $-\sqrt s$ and $\sqrt s$. In either case, the equation $ax^4+bx^3+cx^2+dx+e=0$ has at least one real solution.
[/sp]
[/sp]
Awesome, Opalg!
My attempt revolved around the intermediate value theorem as well, but I tried to work with letting the roots be -1, 0 and 1 and those didn't help at all...therefore thank you so much for the intelligent approach!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
