MHB Prove a_n=⌊2^n√2⌋ contains infinitely many composite numbers
  • Thread starter Thread starter lfdahl
    Composite Numbers
lfdahl
MHB
Prove, that the sequence:
$a_n = \left\lfloor{2^n\sqrt{2}}\right\rfloor,\;\;\;\;n = 1,2,3,..$- contains infinitely many composite numbers.
Mathematics news on Phys.org
Suggested solution:
Suppose that the sequence ${a_n}$ contains only finitely many composite numbers, i.e. there exists an $N$ such that for all $n>N$, $a_n$ is odd.
Consider the binary representation of $a_n$ ($n>N$). The last digit of $a_n$ must be $1$, which in turn implies, that the fractional part of binary representation of $\sqrt{2}$ has all its digits equal to $1$ after the $N$´th position. This contradicts the irrationality of $\sqrt{2}$.
lfdahl said:
Suggested solution:
Hats off to you
kaliprasad said:
Hats off to you
The solution is not mine :o
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
