MHB Prove AM-GM Inequality: What Values to Use?
  • Thread starter Thread starter delc1
    gm Inequality
To prove the AM-GM inequality, the discussion emphasizes using three terms to match the power of three on the left-hand side. The expression \(4x + 10y\) can be restructured by splitting \(4x\) into \(2x + 2x\), allowing the application of AM-GM to the terms \(2x, 2x, 10y\). This leads to the formulation \(\frac{2x + 2x + 10y}{3} \geq (2x \cdot 2x \cdot 10y)^{1/3}\). Ultimately, this results in the conclusion that \((4x + 10y)^3 \geq 1080x^2y\), effectively proving the inequality.
delc1
Could someone please help me with this question:
What values are we meant to use to prove this inequality?
many thanks
Try and put things into a form where you can use the AM-GM inequality. Here you have a power of three on the LHS, which means you're probably going to have to consider AM-GM with three terms. So we try this (note the inequality sign doesn't change because the cube root function is strictly increasing over the positive reals):
$$4x + 10y \geq \sqrt[3]{1080 x^2 y}$$
But we only have two variables here! But look: there's an $x^2$ term on the RHS, and we know that here the RHS will be the geometric mean (and the LHS the arithmetic mean), so that means we probably have two terms in $x$ and one in $y$. First let's put the LHS in the right form as an actual mean, so we get:
$$\frac{12x + 30y}{3} \geq \sqrt[3]{1080 x^2 y}$$
That's looking a bit closer to what we need. So now we want to write the above in the form below where we can directly apply AM-GM:
$$\frac{ax + bx + cy}{3} \geq \sqrt[3]{abc x^2 y}$$
Can you see why once we find good values of $a$, $b$, $c$ we will be able to apply AM-GM directly? (hint: $abcx^2y = (ax)(bx)(cy)$). Can you now solve for $a$, $b$ and $c$ and conclude? (hint: $c$ is already given, so you have a system of two equations in two variables).
Hi delc1,
First I played with the sum of $4x$ and $10y$ and applied the AM-GM and I ended up with $\dfrac{4x+10y}{2}\ge (4x\cdot10y)^{\dfrac{1}{2}}_{\phantom{i}}$. This gave us the idea that if we wanted the power of 3 on one side of the inequaliy sign, we must apply the AM-GM inequality to a total of 3 terms.
Note that $1080=2^33^35$ and that the RHS of the inequality$(4x+10y)^3\ge1080x^2y$ consists of two $x$ and and one $y$, I know I must separate the $4x$ into the sum of $2x+2x$ and by applying the AM-GM to the terms $2x,\,2x,\,10y$, I get:
$\dfrac{2x+2x+10y}{3}\ge (2x\cdot2x\cdot10y)^{\dfrac{1}{3}}_{\phantom{i}}$, or equivalently,
anemone said:
Hi delc1,
Thanks all, the help is always appreciated!
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
