Prove $\inf \{\overline{m}-x: x\in S\}=0$
  • MHB
  • Thread starter alexmahone
In summary, the proof shows that 0 is a lower bound of the set $\{\overline{m}-x: x\in S\}$ and any positive number is not a lower bound. This leads to the conclusion that the infimum of the set is 0.
alexmahone
304
Let $S$ be a non-empty bounded set of real numbers, and $\overline{m}=\sup S$. Prove that $\inf \{\overline{m}-x: x\in S\}=0$.
[Use only the definitions of supremum and infimum, and not identities like $\inf(A+B)=\inf A+\inf B$ and $\inf(-S)=-\sup(S)$.]
Show that 0 is a lower bound of $\{\overline{m}-x\mid x\in S\}$ and that any positive number is not a lower bound.
$x\le\overline{m}$ for all $x\in S$.
$\overline{m}-x\ge 0$ for all $x\in S$.
So, 0 is a lower bound of $\{\overline{m}-x: x\in S\}$. ------ (1)
Assume, for the sake of argument, that $a>0$ is a lower bound of $\{\overline{m}-x: x\in S\}$.
$\overline{m}-x\ge a$ for all $x\in S$.
$x\le\overline{m}-a$
This contradicts the fact that $\overline{m}$ is the least upper bound of $S$.
So, any $a>0$ is not a lower bound of $\{\overline{m}-x: x\in S\}$.
Together with (1), this implies that $\inf\{\overline{m}-x: x\in S\}=0$.
Is that ok?
Yes, this is fine.
First, let us recall the definitions of supremum and infimum. The supremum of a set $S$ is the smallest number that is greater than or equal to every element in $S$. In other words, it is the least upper bound of $S$. On the other hand, the infimum of a set $S$ is the largest number that is less than or equal to every element in $S$. It is the greatest lower bound of $S$.
In this problem, we are given that $S$ is a non-empty bounded set, meaning that it has both an upper and lower bound. Let $\overline{m}=\sup S$. This means that $\overline{m}$ is the smallest number that is greater than or equal to every element in $S$. Now, we need to prove that $\inf \{\overline{m}-x: x\in S\}=0$.
To prove this, we will use the definition of infimum. We need to show that $0$ is the largest number that is less than or equal to every element in $\{\overline{m}-x: x\in S\}$. In other words, we need to show that $0$ is the greatest lower bound of $\{\overline{m}-x: x\in S\}$.
Let $y\in \{\overline{m}-x: x\in S\}$. This means that $y=\overline{m}-x$ for some $x\in S$. Since $\overline{m}$ is the smallest number that is greater than or equal to every element in $S$, we have $y=\overline{m}-x\leq \overline{m}$ for all $x\in S$. This implies that $y\leq \overline{m}$. Since $\overline{m}$ is the smallest upper bound of $S$, we also have $y\leq \overline{m}$ for all $y\in \{\overline{m}-x: x\in S\}$. This means that $0$ is indeed the greatest lower bound of $\{\overline{m}-x: x\in S\}$.
Therefore, we can conclude that $\inf \{\overline{m}-x: x\in S\}=0$. This proves the statement that $\inf \{\over
FAQ: Prove $\inf \{\overline{m}-x: x\in S\}=0$
Q: What does it mean for the infimum of a set to be equal to 0?
A: When the infimum of a set is equal to 0, it means that 0 is the smallest value in the set. In other words, there is no other number in the set that is smaller than 0.
Q: What is an infimum?
A: An infimum is the greatest lower bound of a set, meaning it is the largest number that is less than or equal to all the numbers in the set. It may or may not be an actual element of the set.
Q: How is the infimum of a set calculated?
A: The infimum of a set is calculated by finding the smallest possible value in the set. This can be done by arranging the elements of the set in ascending order and selecting the first number in the list.
Q: What does $\overline{m}$ represent in this equation?
A: In this equation, $\overline{m}$ represents the supremum (or least upper bound) of the set S. This is the smallest number that is greater than or equal to all the numbers in the set.
Q: How is this statement proven?
A: This statement can be proven by showing that 0 is the greatest lower bound of the set $\{\overline{m}-x: x\in S\}$. This can be done by showing that 0 is less than or equal to all the numbers in the set and that there is no other number smaller than 0 that is also less than or equal to all the numbers in the set.
