MHB Prove Log Gamma Integral: $\sqrt{2 \pi}$
The integral of the logarithm of the Gamma function over the interval from 0 to 1 is shown to equal the logarithm of the square root of 2π. The proof utilizes the classical Riemann sum approach and the reflection formula for the Gamma function. By partitioning the interval and applying trigonometric identities, the integral simplifies to a form that reveals the desired result. An alternative method is also presented, confirming the same conclusion through a different series of transformations. Ultimately, both methods lead to the established equality of the integral with ln(√2π).
alyafey22
MHB
Prove the following
$$\int^1_0 \ln\left( \Gamma (x) \right) \, dx = \ln \left( \sqrt{2 \pi } \right) $$
Mathematics news on Phys.org
An elementary evaluation of the integral...
$\displaystyle I = \int_{0}^{1} \ln \Gamma(x)\ dx\ (1)$
... uses the 'classical' Riemann sum. Let's partition the interval [0,1] into n subintervals of length $\frac{1}{n}$ so that is...
$\displaystyle I = \lim_{n \rightarrow \infty} \frac{1}{n}\ \sum_{k=1}^{n} \ln \Gamma(\frac{k}{n})\ (2)$
If n is even we can write...
$\displaystyle \frac{1}{n}\ \sum_{k=1}^{n} \ln \Gamma(\frac{k}{n}) = \frac{1}{n}\ \ln \prod_{k=1}^{n} \Gamma(\frac{k}{n}) = \frac{1}{n}\ \ln \prod_{k=1}^{\frac{n}{2}} \{\Gamma(\frac{k}{n})\ \Gamma (1- \frac{k}{n}) \}\ (3) $
Now we use the 'reflection formula'...
$\displaystyle \Gamma (x)\ \Gamma (1-x) = \frac{\pi}{\sin \pi x}\ (4)$
... to arrive to write...
$\displaystyle \frac{1}{n}\ \sum_{k=1}^{n} \ln \Gamma(\frac{k}{n}) = \frac{1}{n}\ \ln \prod_{k=1}^{\frac{n}{2}} \frac{\pi}{\sin \pi \frac{k}{n}} = \ln \sqrt{\pi} - \ln (\prod_{k=1}^{\frac{n}{2}} \sin \pi \frac {k}{n})^{\frac{1}{n}}\ (5)$
As last step we recall the trigonometric identity...
$\displaystyle \prod_{k=1}^{n} \sin \pi \frac{k}{n} = \frac{n+1}{2^{n}}\ (6)$
... we arrive to write...
$\displaystyle \frac{1}{n}\ \sum_{k=1}^{n} \ln \Gamma(\frac{k}{n}) = \ln \sqrt{\pi} - \frac{1}{n}\ \ln (n+1) + \ln \sqrt{2}\ (7)$
... and now we push n to infinity obtaining...
$\displaystyle I = \int_{0}^{1} \ln \Gamma(x)\ dx = \ln \sqrt{2\ \pi}\ (8)$
Kind regards
$\chi$ $\sigma$
I used a slightly different way
\begin{align*}
\int^1_0 \ln (\Gamma(t)) \, dt
&= \int^1_0 \ln (\Gamma(1-t)) \, dt \\
&= \int^1_0 \ln \left( \frac{\pi } { \Gamma(t) \sin( \pi t)} \right) \, dt \\
&= \int^1_0 \ln \left( \pi \right) \, dt - \int^1_0 \ln( \Gamma(t)) \, dt -\int^1_0 \sin( \pi t) \, dt \\
&= \ln ( \pi ) - \int^1_0 \ln( \Gamma(t)) \, dt + \ln(2) \\
&= \ln (2 \pi ) - \int^1_0 \ln( \Gamma(t)) \, dt \\
&= \ln ( \sqrt{2 \pi} )
\end{align*}
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
