MHB Prove Polynomial Congruence $(x+y)^n \equiv x^n + y^n$ (mod $p$)
  • Thread starter Thread starter lfdahl
    Polynomial
The polynomial congruence $(x + y)^n \equiv x^n + y^n$ (mod $p$) holds true if and only if the exponent $n$ is a power of the prime number $p$. This result can be proven using properties of binomial coefficients and their behavior under modulo $p$. Specifically, when $n$ is not a power of $p$, the binomial expansion introduces terms that do not vanish modulo $p$. The discussion emphasizes the significance of the relationship between the structure of polynomial expressions and prime powers in modular arithmetic. Thus, understanding this congruence is crucial for deeper insights into polynomial identities in number theory.
lfdahl
MHB
Given a prime number $p$, prove that the polynomial congruence
$(x + y)^n \equiv x^n + y^n$ (mod $p$) is true if and only if $n$ is a power of $p$.
Mathematics news on Phys.org
Hint:
Define the polynomial: $$P(x,y) = (x+y)^n-x^n-y^n = \sum_{k=1}^{n-1}{ n\choose k }x^ky^{n-k}$$
Consider the two cases:
(i). $n = p^a$
(ii). $n$ is not a power of $p$.
Suggested solution:
Let \[P(x,y) = (x+y)^n-x^n-y^n = \sum_{k=1}^{n-1}\binom{n}{k}x^{k}y^{n-k}.\]
(a). If $n = p^a$, then all the coefficients of $P$ are divisible by $p$.
Proof: For $1 \leq j \leq p^a-1$, $\binom{p^a}{j}=\frac{p^a}{j}\binom{p^a-1}{j-1}.$
If $j = rp^b$, where $gcd(r,p)=1$, then $\frac{p^a}{j}=\frac{p^{a-b}}{r}$, where $a-b \geq 1$ (since $j < p^a$). Thus $r$ must divide $\binom{p^a-1}{j-1}$ (since $\binom{p^a}{j}$ is an integer), and $\binom{p^a}{j}$ is divisible by $p^{a-b}$.
(b). If $n$ is not a power of $p$, then not all $\binom{n}{j}$ are divisible by $p$.
Proof: For $p^a < n < p^{a+1}$, let $c = n – p^a$ so $0 < c < p^a(p-1)$. Then $\binom{n}{c} = \binom{p^a+c}{c} = \prod_{j=1}^{c}\frac{p^a+j}{j}$. If $j = rp^b$, where $gcd(r,p) = 1$ and $b<a$, then $\frac{p^a+j}{j} = \frac{p^{a-b}+r}{r}$. From this $\binom{n}{c}$ equals a product of fractions none of whose numerators is a multiple of $p$.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 48 ·
  • · Replies 96 ·
12K
