I Prove $$T_{p}M$$ is a vector space with the axioms
Delong66
Suppose M is a manifold and $$T_{p}M$$ is the tangent space at a point $$p \in M$$. How do i prove that it is indeed a vector space using the axioms:
Suppose that u,v, w $$\in V$$. where u,v, w are vectors and $$\V$$ is a vector space
$$u + v \in V \tag{Closure under addition}$$
$$u + v = v + u \tag{Commutative property}$$
$$u + (v+w)=(u+v)+w \tag{Associative property}$$
V has a zero vector 0 such that for every $$\u \in \V$$, $$u+0=u$$. $$\tag{Additive identity}$$
For every $$u \in V$$, there is a vector in V denoted by −u such that u+(−u)=0. $$\tag{Additive inverse}$$
Now let's also assume that $$c,d \in \mathbb R$$
$$cu \in V \tag{Closure under scalar multiplication}$$
$$c(u+v)=cu+cv \tag{Distributive property}$$
$$(c+d)u=cu+du \tag{Distributive property}$$
$$c(du)=(cd)u \tag{Associative property}$$
$$1(u)=u \tag{Scalar identity}$$
You listed the axioms of a vector space, but how do you define the tangent space? What does an element of ##T_pM## look like?
Likes Orodruin and topsquark
Definition 1: Suppose M a differentiable manifold and $$p\in M$$.
A funtion $$f:M \rightarrow \mathbb{R}$$ is differentiable at $$p \in M$$ iff $$\exists U_p \subset M$$ : $$f:U_p \rightarrow \mathbb{R}$$ is differentiable.
Definition 2:Dp ={set of all differentiable functions at p in M}
Definition 3: Suppose M a differentiable manifold and $$p\in M$$.
A tangent vector at $$p\in M$$ is an operator $$v:D_p \rightarrow \mathbb{R} \quad : \quad f \mapsto v(f)$$ with
i) $$v(mf+ng)=mv(f)+nv(g) \quad \forall f,g \in D_p$$
ii)$$v(fg)=v(f)g(p)+f(p)v(g) \quad \forall f,g \in D_p$$
Definition 4: TpM={set of all tangent vectors at p in M}
Definitions 1 and 2 define the differentiability at points of ##M,## i.e. differential functions, not their tangents.
Definition 3 defines one tangent vector, definition 4 defines the set of all tangent vectors. However, it does not tell anything about the relation between two such operators ##v## and ##w.## We now have a set, nothing more. How do we make this set a vector space?
We need to define ##v+w## so we set: ##(v+w)(f):=v(f)+w(f)## and ##(\alpha v)(f):=\alpha \cdot v(f).##
This makes the set of derivations, the operators, a linear space. The axioms follow automatically.
If you want to calculate something, then consider curves on ##M## through ##p## and calculate actual tangent vectors and show that ##D_p(v+w)(f)=D_p(v)(f)+D_p(w)(f).## You can also use the coordinate directions and partial derivatives:
D_p(v)(f)=\sum_{i=1}^n\, v_i\, \frac{\partial f}{\partial x_i}(p)
This could also help (##p=x_0, J=D, J## for Jacobi matrix)
https://www.physicsforums.com/insights/pantheon-derivatives-part-ii/
Hello! There is a simple line in the textbook. If ##S## is a manifold, an injectively immersed submanifold ##M## of ##S## is embedded if and only if ##M## is locally closed in ##S##. Recall the definition. M is locally closed if for each point ##x\in M## there open ##U\subset S## such that ##M\cap U## is closed in ##U##. Embedding to injective immesion is simple. The opposite direction is hard. Suppose I have ##N## as source manifold and ##f:N\rightarrow S## is the injective...
