Prove that a root of an equation is in the interval (1,1+1/k)
In summary, an equation root is a value that, when substituted into an equation, makes the equation true. "In the interval (1,1+1/k)" means that the root of the equation must be greater than 1 and less than 1 + 1/k, where k is a constant. To prove that a root is in the interval (1,1+1/k), the Intermediate Value Theorem can be used. It is important to prove that a root is in a specific interval as it helps to narrow down the possible solutions to an equation. A root of an equation can be in multiple intervals, meaning there may be multiple values that satisfy the equation within different ranges. It is important to consider all possible intervals when
anemone
MHB
POTW Director
3,883
115
Show that for every integer $k\ge 2$, the equation $x^k+\dfrac{1}{x^k}=1+x$ has a root in the interval $\left(1, 1+\dfrac{1}{k} \right)$.
Mathematics news on Phys.org
Solution of other:
Let $P(x)=x^k+\dfrac{1}{x^k}-x-1$. First, we show that $P\left(1+\dfrac{1}{k}\right)>0$.
For $k=2$, we have $P\left(1+\dfrac{1}{2}\right)=\dfrac{7}{36}>0$.
For $k\ge 3$, the Binomial Theorem implies that
$\left(1+\dfrac{1}{k}\right)^k>1+k\left(\dfrac{1}{k}\right)+\dfrac{k(k-1)}{2}\cdot\dfrac{1}{k^2}=2+\dfrac{k-1}{2k}\ge 2+\dfrac{1}{k}$
Thus, $P\left(1+\dfrac{1}{k}\right)>\left(1+\dfrac{1}{k}\right)^k-\left(1+\dfrac{1}{k}\right)-1>0$
Next, we let $Q(x)=x^kP(x)=x^{2k}-x^{k+1}-x^k+1$. Then it is easy to verify that $Q(x)=(x-1)f(x)$, where
$f(x)=x^{2k-1}+x^{2k-2}+\cdots+x^{k+2}+x^{k+1}-x^{k-1}-x^{k-2}-\cdots-x-1$
Since $P\left(1+\dfrac{1}{k}\right)>0$, we deduce that $Q\left(1+\dfrac{1}{k}\right)>0$ and $f\left(1+\dfrac{1}{k}\right)>0$. But $f(1)=k-1-k=-1<0$, thus the Intermediate Value Theorem implies that there exists $m\in\left(1,\,1+\dfrac{1}{k}\right)$ such that $f(m)=0$. It then follows that $P(m)=0$.
FAQ: Prove that a root of an equation is in the interval (1,1+1/k)
What is an equation root?
An equation root is a value that, when substituted into an equation, makes the equation true.
What does "in the interval (1,1+1/k)" mean?
This means that the root of the equation must be greater than 1 and less than 1 + 1/k, where k is a constant. In other words, the root must fall within a specific range.
How do you prove that a root of an equation is in the interval (1,1+1/k)?
To prove that a root is in the interval (1,1+1/k), you can use the Intermediate Value Theorem. This theorem states that if a continuous function has values f(a) and f(b) that are of opposite signs, then there exists a value c between a and b where f(c) = 0. In this case, if a root exists within the interval (1,1+1/k), then it must be between two values with opposite signs and can therefore be proven to exist.
Why is it important to prove that a root is in the interval (1,1+1/k)?
Proving that a root is in a specific interval is important because it helps to narrow down the possible solutions to an equation. This can be useful in many applications, such as finding the maximum or minimum value of a function or determining the range of possible values for a variable.
Can a root of an equation be in multiple intervals?
Yes, it is possible for a root of an equation to be in multiple intervals. This means that there may be multiple values that satisfy the given equation within different ranges. It is important to consider all possible intervals when solving an equation to ensure that all roots are accounted for.
