I Prove that a triangle with lattice points cannot be equilateral
The discussion centers on proving that a triangle with lattice points cannot be equilateral. The user begins by defining three lattice points and applying the distance formula to establish equal side lengths. Through algebraic manipulation, they conclude that for the triangle to exist, one of the coordinates must equal another, resulting in a degenerate triangle. The conversation also touches on using a general approach with lattice points, leading to contradictions in the derived equations. Ultimately, the analysis supports the assertion that an equilateral triangle cannot be formed with lattice points.
JoeAllen
I assumed three points for a triangle P1 = (a, c), P2 = (c, d), P3 = (b, e)
and of course:
a, b, c, d, e∈Z
Using the distance formula between each of the points and setting them equal:
\sqrt { (b - a)^2 + (e - d)^2 } = \sqrt { (c - a)^2 + (d - d)^2 } = \sqrt { (b - c)^2 + (e - d)^2 }(e+d)2 = (c-a)2 - (b-a)2
(e+d)2 = (c-a)2 - (b-c)2
c2 - 2ac - b2 +2ab = -2ac + a2 - b2 + 2bc
c2 + 2ab = a2 + 2bc
c(c - 2b) = a(a - 2b)
Thus, for this to be true, a = c. But in this example, the distance between a and c would be 0. Thus, not a triangle and certainly not an equilateral triangle.
Where did I go wrong here? I'm bored waiting for Calculus II in the Fall and I'm going through Courant's Differential and Integral Calculus on my free time until then (Fall term probably starting in August/September, so I'm not worried if it takes a few months to get comfortable with Courant - Calculus I has been a breeze since I already knew most of the content before taking it).
Mathematics news on Phys.org
As for 2D lattice we can make one of the lattice points is (0,0) without losing generality.
Say other points are ##(n_1,n_2),(m_1,m_2)##
n_1^2+n_2^2=A
m_1^2+m_2^2=A
(n_1-m_1)^2+(n_2-m_2)^2=A
where A is square of the side length. You will find contradiction in this set of formla.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
