Prove that every subset ##B## of ##A=\{1,...,n\}## is finite
  • Thread starter Thread starter zenterix
    Real analysis
zenterix
Prove that every subset ##B## of ##A=\{1,...,n\}## is finite.
Note that the definition of a finite set is that either a set is empty or there exists a bijection between the set and ##\{1,2,...,n\}## for some ##n\in\mathbb{N}##.
I am very unsure about the proof below. I'd like to know if it is correct.
If ##B## is empty then it is finite by definition.
If ##B## is non-empty then since ##B\subset\mathbb{N}## it has a smallest element ##b_1##.
If ##B \backslash \{b_1\}## is non-empty then it has a smallest element ##b_2##.
If ##B \backslash \{b_1, b_2\}## is non-empty then it has a smallest element ##b_3##
If we keep repeating this procedure, we will eventually reach the empty set after a maximum of ##n## steps.
The reason for this is that we obtain an element of ##B## in each step (the smallest element in that step), and if we were to obtain more than ##n## elements then ##B## would have more elements than ##\{1, 2, ..., n\}## of which ##B## is a subset.
Suppose that we reach the empty set after ##m\leq n## steps. We have ##b_1, b_2, ..., b_m## elements obtained from these steps.
Define ##g:B\to\{1,...,m\}## by
##g(b_i)=i## for ##i=1,2,...,m##
Claim: ##g## is a bijection.
Proof
Suppose ##g(b_i)=g(b_j)## for any ##b_i, b_j\in B##.
Then by definition of ##g## we have ##i=j## and hence ##b_i=b_j##
Thus, ##g## is injective.
Now, let ##i\in\{1,...,m\}##. Then ##g(b_i)=i## and so ##g## is surjective.
Thus we have obtained a bijection between ##B## and ##\{1,...,m\}## and so ##B## is finite.
Using induction might be simpler.
For non-empty B it suffices to find a surjection \phi : S\to B for some finite S, since then |B| \leq |S| with equality iff \phi is a bijection.
Doesn't finding such a finite ##S## have to go through some procedure like the one in my OP?
That is, don't we have to somehow construct ##S## and isn't that precisely the part of the proof that is the trickiest?
Instead of finding a surjection I found a bijection directly.
Induction must be the way to go.
