Prove that ##\lim\limits_{x \to \infty} f(x) = 0##
Meden Agan
For ##x > 0##, let ##f(x)## be the minimum value of ##\left|x-\sqrt{m^2+2 \, n^2}\right|## for all integers ##m, n##. Then, prove that $$\lim_{x \to \infty} f(x)=0.$$
Calculus, Number Theory.
Let ##f(x)= \min\limits_{m, n \in \mathbb Z} \left|x- \sqrt{m^2+2 \, n^2}\right|## be the minimum distance between a positive real ##x## and a number of the form ##\sqrt{m^2 + 2 n^2}## with ##m, n## integers.
Let us consider a radius ##R## and let us consider the set ##S_R## of integer points satisfying ##m^2 + 2 n^2 \le R^2##.
The ellipse enclosing them has area ##A(R) = \dfrac{\pi R^2}{\sqrt 2}##, and number geometry ensures its number of integer points ##N(R)## grows as ##\dfrac{\pi}{\sqrt 2} R^2## plus an error - proportional to ##R##; i.e. there exist positive constants ##c_1## and ##c_2## such that ##c_1 \, R^2 \le N(R) \le c_2 \, R^2## for ##R## large enough.
Each pair ##(m, n) \in S_R## determines the distance ##r = \sqrt{m^2+2 \, n^2}## between ##0## and ##R##. Two pairs can produce the same ##r##, but there are few coincidences with respect to ##N(R)##. Thus the number ##M(R)## of different distances satisfies ##M(R) \ge c_3 \, R^2## for a constant ##c_3 > 0##. By ordering these distances ##0 = r_0 < r_1 < \ldots < r_{M(R)-1} \le R##, the mean space between two consecutive distances is ##\dfrac{R}{M(R)} \le \dfrac{1}{c_3 \, R}##.
Now, if we choose a large ##x## and set ##R \approx x##, one of the ##r_k##s falls within at most ##\dfrac{1}{c_3 \, x}## from ##x##. Then, ##f(x) \le K/ x## with ##K = 1/c_3##. Since ##K/x## approaches zero when ##x \to \infty##, it immediately follows that $$\lim_{x \to \infty} f(x) = 0.$$
The values ##\sqrt{m^2+2 \, n^2}## become so dense on the positive half-line that the minimum deviation from any real number cancels as ##x## increases.
Is that correct?
A point to consider is why the function is well defined, i.e, why does the minimum exist for ##x>0##. (If it doesn't then change minimum to infimum)
Assuming the function is well defined and the limit exists, then the limit must be zero, because we'll just pick a sequence ##x_n = \sqrt{1+2n^2}\to\infty##, for example. The minimum is constantly zero along this sequence, so zero is the only limit candidate.
(Side note: a valid proof would also be to show that the limit is zero along any sequence ##x_n\to\infty##)
It is a correct approach to show ##xf(x)## is bounded as ##x\to\infty##, but I just don't understand what precedes it :/ A more low level explanation for the existence of the constants would be helpful.
Likes Meden Agan and Mark44
Mhm, could you outline what's unclear step by step? Hope I can provide a detailed clarification.
Specifically this part.
What I understand is we consider the set of integer points bounded by the ellipse
\frac{x^2}{R^2} + \frac{y^2}{\left(\frac{R}{\sqrt{2}} \right)^2} = 1
Are you saying that ##N(R)## is equivalent to ##cR^2 + \mbox{Error}(R)## as ##R\to\infty##? Why is that true and why does this imply existence of said constant ##c_1,c_2##?
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
