Prove that ## \sum_{d\mid n}\sigma_{1}(d)\sigma_{1}(\frac{n}{d}) ##
  • Thread starter Thread starter Math100
The discussion centers on proving the equality ## \sum_{d\mid n}\sigma_{1}(d)\sigma_{1}(\frac{n}{d}) = \sum_{d\mid n}d\sigma_{0}(d)\sigma_{0}(\frac{n}{d}) ##, where ## \sigma_0(n) ## counts the divisors of ## n ## and ## \sigma_1(n) ## sums them. Participants explore the definitions of the functions involved, particularly the Dirichlet product, and how they relate to the prime factorization of ## n ##. Various proofs and examples are discussed, including specific cases like ## n=3^3 ## and ## n=15 ##, to illustrate the equality. The conversation highlights the complexity of the proof and the need for clarity in defining the functions used. Ultimately, the proof is confirmed through examples, demonstrating that the two summations are indeed equal.
Math100
By considering ## u\cdot u\cdot N\cdot N ##, prove that ## \sum_{d\mid n}\sigma_{1}(d)\sigma_{1}(\frac{n}{d})=\sum_{d\mid n}d\sigma_{0}(d)\sigma_{0}(\frac{n}{d}) ##.
None.
Proof:
Let ## n\in\mathbb{N} ##.
Then ## \sigma_{\alpha}(n)=(u\cdot N^{\alpha})(n) ## for ## \alpha\neq 0 ## and ## \sigma_{0}(n)=(u\cdot u)(n) ##
such that ## u(n)=1, N(n)=n ## for all ## n ##.
By considering ## u\cdot u\cdot N\cdot N ##, we have that
\begin{align*}
&\sigma_{1}\cdot \sigma_{1}=(u\cdot N)\cdot (u\cdot N)\\
&=(N\cdot u)\cdot (u\cdot N)\\
&=N\cdot (u\cdot u)\cdot N\\
&=N\cdot \sigma_{0}\cdot N\\
&=\sigma_{0}\cdot (N\cdot N).\\
\end{align*}
Observe that
\begin{align*}
&(\sigma_{1}\cdot \sigma_{1})(n)=[\sigma_{0}\cdot (N\cdot N)](n)\\
&=\sum_{d\mid n}\sigma_{0}(\frac{n}{d})(N\cdot N)(d)\\
&=\sum_{d\mid n}\sigma_{0}(\frac{n}{d})\sum_{d_{1}\mid d}N(d_{1})N(\frac{d}{d_{1}})\\
&=\sum_{d\mid n}\sigma_{0}(\frac{n}{d})\sum_{d_{1}\mid d}d_{1}(\frac{d}{d_{1}})\\
&=\sum_{d\mid n}\sigma_{0}(\frac{n}{d})\sum_{d_{1}\mid d}d\\
&=\sum_{d\mid n}\sigma_{0}(\frac{n}{d})d\sum_{d_{1}\mid d}1\\
&=\sum_{d\mid n}\sigma_{0}(\frac{n}{d})d\sum_{d_{1}\mid d}u(d_{1})u(\frac{d}{d_{1}})\\
&=\sum_{d\mid n}\sigma_{0}(\frac{n}{d})d[(u\cdot u)(d)]\\
&=\sum_{d\mid n}d\sigma_{0}(d)\sigma_{0}(\frac{n}{d}).\\
\end{align*}
Since ## (\sigma_{1}\cdot \sigma_{1})(n)=\sum_{d\mid n}\sigma_{1}(d)\sigma_{1}(\frac{n}{d}) ##,
it follows that ## \sum_{d\mid n}\sigma_{1}(d)\sigma_{1}(\frac{n}{d})=\sum_{d\mid n}d\sigma_{0}(d)\sigma_{0}(\frac{n}{d}) ##.
Therefore, ## \sum_{d\mid n}\sigma_{1}(d)\sigma_{1}(\frac{n}{d})=\sum_{d\mid n}d\sigma_{0}(d)\sigma_{0}(\frac{n}{d}) ##.
Math100 said:
Homework Statement:: By considering ## u\cdot u\cdot N\cdot N ##, prove that ## \sum_{d\mid n}\sigma_{1}(d)\sigma_{1}(\frac{n}{d})=\sum_{d\mid n}d\sigma_{0}(d)\sigma_{0}(\frac{n}{d}) ##.
Relevant Equations:: None.
Proof:
How is ##\sigma_0## defined? E.g. you have a variable (or constant) ##u## on the right but not on the left. Then you have ##u## and ##u(n)##, same with ##N##. This is confusing.
I know ##\sigma_k(n)=\displaystyle{\sum_{d|n}d^k}## for ##k\in \mathbb{N}_0.## Would that be correct?
It means that ## \sigma_0(n)## counts all divisors of ##n## and ##\sigma_1(n)## adds them. Right?
I think the hint means that ##\sigma_k(a\cdot b)=\sigma_k(a)\cdot\sigma_k(b)## for any coprime numbers ##a,b.## I would work with the prime decomposition of ##n.##
How can the prime decomposition of ## n ## work in here?
Do you mean ## \sigma_{\alpha}(p_{1}^{a_{1}}\dotsb p_{k}^{a_{k}})=\sigma_{\alpha}(p_{1}^{a_{1}})\dotsb \sigma_{\alpha}(p_{k}^{a_{k}}) ##?
If ##n=p_1^{k_1}\cdot\ldots\cdot p_r^{k_r}## then all ##p_i^{k_i},p_j^{k_j}## are coprime if ##i\neq j.## Therefore
\sigma_0(n)=\prod_{i=1}^r \sigma_0(p_i^{k_i}) \text{ and } \sigma_1(n)=\prod_{i=1}^r \sigma_1(p_i^{k_i})
Now first prove the formula for ##n=p^k.## Then we see how it works for a product of two, say ##p^k\cdot q^m,## which probably shows us the way for any value of ##r.##
Yes, ## \sigma_{0}(n) ## is the number of the divisors of ## n ##, and ## \sigma_{1}(n) ## is the sum of the divisors of ## n ##.
## \sigma_{0}(p^{k})=k+1 ##
## \sigma_{0}(p^{k})=1^{0}+p^{0}+p^{2\cdot 0}+\dotsb +p^{k\cdot 0}=k+1 ##
## \sigma_{1}(p^{k})=1^{1}+p^{1}+p^{2\cdot 1}+\dotsb +p^{k\cdot 1}=\frac{p^{k+1}-1}{p-1} ##
Yes, and that means we have the divisors ##\{1,p,p^2,\ldots,p^k\}.## Thus
\begin{align*}
\sum_{d|n}d\sigma_{0}(d)\sigma_{0}(\frac{n}{d})&=\sum_{m=0}^kp^m\cdot \sigma_{0}(p^m)\sigma_{0}(p^{k-m})=\sum_{m=0}^kp^m\cdot (m+1)\cdot (k-m+1)\\
\sum_{d|n}\sigma_{1}(d)\sigma_{1}(\frac{n}{d})&=\sum_{m=0}^k \dfrac{p^{m+1}-1}{p-1}\cdot\dfrac{p^{k-m+1}-1}{p-1}
\end{align*}
O.k., that looks like a lot of work to do. Maybe the idea wasn't the best way. My problem was that ##d## and ##\dfrac{n}{d}## aren't necessarily coprime so the multiplicativity of ##\sigma_k## isn't useful.
Let us simply check an example.
##n=3^3##.
\begin{align*}
\sum_{d|n}d\sigma_{0}(d)\sigma_{0}(\frac{n}{d})&=\sigma_{0}(1)\sigma_{0}(27)+3\sigma_{0}(3)\sigma_{0}(9)+9\sigma_{0}(9)\sigma_{0}(3)+27\sigma_{0}(27)\sigma_{0}(1)\\
&=4+3\cdot 2\cdot 3+9\cdot 3\cdot 2 +27 \cdot 4= 184\\
\sum_{d|n}\sigma_{1}(d)\sigma_{1}(\frac{n}{d})&=\sigma_{1}(1)\sigma_{1}(27)+\sigma_{1}(3)\sigma_{1}(9)+\sigma_{1}(9)\sigma_{1}(3)+\sigma_{1}(27)\sigma_{1}(1)\\
&=40+4\cdot 13+13\cdot 4 +40=184
\end{align*}
I do not see how this could be done without the work since the summands are so differently.
Could it be that ##n## is assumed to be square-free?
\begin{align*}
\end{align*}
##n=3^3##.
\begin{align*}
\end{align*}
Sorry, may I know how to find ## \sigma_{0}(1), \sigma_{0}(27), ##, etc?
Your formulas were correct, but I was lazy. I looked them up here:
https://de.wikipedia.org/wiki/Teilerfunktion
The sum over all divisors makes it complicated. That's why I asked if ##n## could be assumed square-free.
Never mind, I found out how to find those ## \sigma_{0}(1), \sigma_{0}(27) ##. But if my formulas were correct, then is there anything I need to fix in my previous, first proof for this problem? What would you add/fix anything to it?
I haven't understood a word of your proof. What are ##u## and ##N## in case of ##n=27##?
I think I should have included/added a definition of the Dirichlet product.
I am not sure. What should ## u, N ## be? Because I think ## u, N ## are arithmetical functions and we write ## (u\cdot N)(n) ## for ## \sum_{d\mid n}\sigma_{1}(d)\sigma_{1}(\frac{n}{d}) ##.
## \sigma_{\alpha}=u\cdot N^{\alpha} ## and ## N=\phi\cdot u ##
From above, how should I find ## u, N ##?
Let us see whether the case that ##n## is square-free is easier. Square-free means that all primes occur only once in the factorization of ##n.##
Let ##n=p_1\cdot\ldots\cdot p_r.## Then
\begin{align*}
\sum_{d|n}\sigma_1(d)\sigma_1(n/d)&=2 \sigma_1(n) +\sum_{i=1}^r (p_i+1)\cdot \prod_{j\neq i} (p_j+1)=(2+r)\prod_{j=1}^r(p_j+1)\\
\sum_{d|n}d\sigma_0(d)\sigma_0(n/d)&= (1+n)\cdot 2^r +\sum_{i=1}^r p_i \cdot 2\cdot \prod_{j\neq i} 2= 2^r\left(1+n+\sum_{i=1}^r p_i\right)
\end{align*}
Applied to ##n=3\cdot 5=15## we get
\begin{align*}
\sum_{d|n}\sigma_1(d)\sigma_1(n/d)&=\sigma_1(1)\sigma_1(15)+\sigma_1(3)\sigma_1(5)+\sigma_1(5)\sigma_1(3)+\sigma_1(15)\sigma_1(1)\\
&=2\cdot 24 +2\cdot 4\cdot 6=96\\
\sum_{d|n}d\sigma_0(d)\sigma_0(n/d)&=\sigma_0(1)\sigma_0(15)+3\cdot \sigma_0(3)\sigma_0(5)+5\cdot \sigma_0(5)\sigma_0(3)+15\sigma_0(15)\sigma_0(1)\\
&=16\cdot 4+ 8\cdot 2 \cdot 2 =96
\end{align*}
If I look at the fact that the summands are so different, then it is hard to see a smart proof without additional formulas. I assume they are behind those ##u## and ##N## functions that I do not know.
\begin{align*}
\end{align*}
\begin{align*}
\end{align*}
How about ## \sigma_{1}\cdot \sigma_{1}=N\sigma_{0}\cdot \sigma_{0} ## where
## \sigma_{1}=N\cdot u ## and ## \sigma_{0}=u\cdot u ##?
Thus
\begin{align*}
&\sigma_{1}\cdot \sigma_{1}=(N\cdot u)\cdot (N\cdot u)\\
&\sigma_{1}\cdot \sigma_{1}=(u\cdot N)\cdot (N\cdot u)\\
&\sigma_{1}\cdot \sigma_{1}=u\cdot (N\cdot N)\cdot u\\
&\sigma_{1}\cdot \sigma_{1}=u\cdot N\sigma_{0}\cdot u\\
&\sigma_{1}\cdot \sigma_{1}=N\sigma_{0}\cdot (u\cdot u)=N\sigma_{0}\cdot \sigma_{0}\\
\end{align*}
where ## N\cdot N=\sum_{d\mid n}d\cdot \frac{n}{d}=n\sum_{d\mid n}1=N\sigma_{0} ##.
If this works, then how should I proceed from here and prove that they're equal?
Thus
\begin{align*}
\end{align*}
I still have no idea what that should mean.
Thus
\begin{align*}
\end{align*}
The above should be ##(N \cdot N)(n) = \ldots = (N\sigma_0)(n)##. (why?)
I think this is a right idea but there is a lot being used without explicit mention, which i think maybe makes it hard to follow. Somewhere we might mention "We will write the Dirichlet product of two arithmetic functions ##f, g## as ##f \cdot g##" (i would use ##\ast## instead of ##\cdot## but just my opinion). Otherwise, how will the reader know? Some other things that might also add clarity:
-Give the definition of Dirichlet product
-State its properties: is it associative? commutative?
-Explicitly define ##u,N,\sigma_k##, e.g., "We define the functions ##u(n) = 1## for all ##n## and ##N(n) = n## for all ##n## and etc..."
-Give an explanation why we have ##\sigma_1=N\cdot u## and ##\sigma_0 = u\cdot u##, even if the explanation is just "From the textbook we know...". At least for me, it was hard to see why those two equations are true...
Some of this could be put in the "Relevant equations" part of the homework template (for future reference). To your last question, you've shown ##\sigma_1\cdot\sigma_1 = (N\sigma_0)\cdot\sigma_0##. Are we done?To build off of fresh's suggestion, if ##f, g## are multiplicative, then their Dirichlet product is multiplicative. So i think another solution would be to prove the equation holds for prime powers (as fresh suggested).
  • · Replies 19 ·
