Prove that T(G) is subgroup of G
  • Thread starter Thread starter ilyas.h
    Subgroup
ilyas.h
subgroup axioms:
1. a, b in T(G), then ab in T(G)
2. existence of identity element.
3. a in T(G), then a^-1 in T(G)
let a be in T(G), then a^n = e.
let b be in T(G), then b^n = e
(ab)^n = (a^n)(b^n) = (e)(e) = e
axiom 1 holds.
2.
let e be in T(G), then e^n = e
conclusion: identity element, e, of G, must be 1.
3.
show that (a^-1)^n = e
(a^-1)^n = (a^n)^-1 = 1 / a^n = 1 / e
therefore
(a^-1)^n = 1 / e
we know from axiom 2 that e = 1, so:
1 / e = e.
Done.
Is my proof correct? there's not markscheme, can't check answer,
There is an error in showing that T is closed under the operation. If x is in T then there exist some number, n, such that x^n= e. If y is in T then there exist some integer m such that y^m= e. You CANNOT assume that m and n are the same. So look at (xy)^{mn}= (x^n)^m(x^m)^n.
To show that there is an identity element you start by saying "Let e be in T(G) then e^n= e and then say "conclusion: identity element of G, e, is 1". That is meaningless!
First, there is no "1" mentioned in the problem. Further, you simply assert that e is in T(G), not that it is an identity element. Nothing you say there has any connection to there being an identity element in T(G).
Instead start by saying "Let e be the identity of G (NOT T(G)). Then, because e^n= e (for all n, not just one), e is in T(G). And since T(G) is a subgroup of G it is also true that ex= xe= x for any x in G. Therefore e, the identity for G, is also the identity for T(G).
Whether you can simply assert that (a^-1)^n= (a^n)^-1 depends upon previous theorems you have proved. Of course, it is true that, since G is abelian, (a^n)(a^-1)^n= e (do you see why "abelian is important?) so that (a^-1)^n= (a^n)^-1.
1.
a in T, there exists n such that a^n = e
b in T, there exists m such that b^m = e
(ab)^mn = (a^n)^m (b^m)^n = e^m e^n = e
axiom 1 holds.
2.
let e be identiy in G
e^n = e ==> e in T(G)
T(G) subgroup of G, it's also true that ea = ae =a for all a in G
conclusion: idenity of G, e, is also identity for T(G).
Axiom 2 holds.
3.
this is where I am confused:
Prove that : a in T(G) ====> a^-1 in T(G)
proof:
(a^-1)^n = e
(a^n) (a^-1)^n = (a^n) e
(a)^n (a^-1)^n = (a^n)
(a a^-1)^n = a^n
e^n = a^n
and a^n = e, so:
e^n = e
LHS = RHS
axiom 3 holds.
Am i going along the right lines?
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
