Prove that the product of 4 consecutive numbers cannot be a perfect square
In summary: This is part of a proof by contradiction. The original statement is that n(n + 1)(n + 2)(n + 3) can't be a perfect square. In the proof by contradiction, we assume that n(n+1)(n+2)(n+3) is a perfect square. Then, by contradiction, we get that n(n+1)(n+2)(n+3) = (n+a)^4.
Vriska
138
n(n+1)(n+2)(n+3) cannot be a square
Uniqueness of prime factors for a given number
I'm not sure but I think I've proved a stronger case for how product of consecutive numbers cannot be squares. I don't know whether it is right
proof :
The product of two consecutive numbers are coprime so cannot be square
in the product of three consecutive numbers eg n(n+1)(n+2), two of those consecutive numbers are divisible by 2 and not a square number but the other isn't divisible by 2 . If that other is a perfect square, then also the product of a square and a nonsquare number cannot be square .Thus 3 consecutive numbers cannot form a perfect square
Now consider 4 numbers n(n+1)(n+2)(n+4). There are 3 consecutive numbers such that their products are divisible by 3 but are not a perfect square . The other number isn't divisible by 3 therefore product of 4 consecutive numbers cannot be perfect square . Thus so on and forever.
Agh, I meant product !
I corrected the title.
Thanks
btw would you know why I've got no response yet? Is what I've written badly wrong or am I just not clear enough here ?
Here's a different approach that is less wordy. If n(n + 1)(n + 2)(n + 3) is a perfect square, it must be equal to ##(n + a)^4## for some integer a, and for all integers n.
Expanding the two expressions, we get ##n^4 + 6n^3 + 11n^2 + 6n## and ##n^4 + 4an^3 + 6a^2n^2 + 4a^3n + a^4##. Equate the coefficients to see that the original expression can't be a perfect square.
Likes opus
Ah hello, thanks for the response
Can you tell me why you put it as (n+a)^4 ? surely if it's a perfect square it should be of form k^2 where k = n + a. we can't say if k will remain an integer if another root is taken to make it to the fourth power .
##(n + a)^2## won't give us the fourth powers that we have when we expand n(n + 1)(n + 2)(n + 3). ##(n + a)^4## is a perfect square (of ##(n + a)^2##).
I dunno, say for example that n(n+1)(n+2)(n+3) leads to a number like 9 ie 3*3 . this cannot be written as a fourth power in form (n+a)^4, can it ?
Can 9 be written as the product of four consecutive integers? If not, then it doesn't matter that 9 isn't a perfect fourth power.
I really can't see why n(n + 1)(n + 2)(n + 3) = (n+a)^4 has to be true for all n. If it isn't true, than equating coefficients isn't valid.
Your method would also prove that n(n+1)(n+2)(n+5) can't be a perfect square, which has an obvious counterexample.
This is part of a proof by contradiction. The original statement is that n(n + 1)(n + 2)(n + 3) can't be a perfect square. In the proof by contradiction, we assume that n(n + 1)(n + 2)(n + 3) is a perfect square, and look for a contradiction.
Likes opus
Shouldn't that be ##(n^2+a)^2##?
I agree completely. I don't think that is valid. One way to actually do this is to multiply ##n(n+1)(n+2)(n+3)## out and notice that it's pretty close to being the square of something. How close is it to being a square?
Likes PeroK
Could be. I know that we have to have four factors of n, but I haven't worked the problem out.
An arbitrary square is of the form ##(n^2 + a)^2##, but not necessarily ##(n+a)^4##.
And, as others have pointed out you are looking for a single solution for ##n, a##, not polynomial equality for all ##n##.
FAQ: Prove that the product of 4 consecutive numbers cannot be a perfect square
What is meant by "product of 4 consecutive numbers"?
The product of 4 consecutive numbers refers to the result of multiplying 4 numbers that come one after the other in a sequence. For example, the product of 2, 3, 4, and 5 is 2*3*4*5=120.
What is a perfect square?
A perfect square is a number that is the product of two equal integers. For example, 9 is a perfect square because it is equal to 3*3.
Why can't the product of 4 consecutive numbers be a perfect square?
This is because the product of 4 consecutive numbers will always have an odd number of factors. A perfect square, on the other hand, will have an even number of factors. Since the number of factors is different, the product of 4 consecutive numbers cannot be a perfect square.
Can you provide an example to prove this statement?
Yes, let's take the numbers 2, 3, 4, and 5 as an example. Their product is 2*3*4*5=120. This number has the factors 1, 2, 3, 4, 5, 6, 8, 10, 12, 15, 20, 24, 30, 40, 60, and 120. As you can see, there are 16 factors, which is an even number. Therefore, 120 cannot be a perfect square.
Is there a general proof for this statement?
Yes, there is a general proof for this statement. It involves using the concept of prime factorization and showing that the product of 4 consecutive numbers will always have an odd number of prime factors, while a perfect square will have an even number of prime factors. This means that the two numbers can never be equal, and therefore the product of 4 consecutive numbers cannot be a perfect square.
