Prove that the sequence does not have a convergent subsequence
fabiancillo
Hello i have problems with this exersice
Let $$\{X_{\alpha}\}_{\alpha \in I}$$ a collection of topological spaces and $$X=\prod_{\alpha \in I}X_{\alpha}$$ the product space. Let $$p_{\alpha}:X\rightarrow X_{\alpha}$$, $$\alpha\in I$$, be the canonical projections
a)Prove that a sequence $$\{a_n\}$$ converges on $$X$$ if and only if the sequence $$\{p_{\alpha}(a_n)\}$$ converges on $$X_{\alpha}$$ for all $$\alpha \in I$$.
b) Let $$I$$ the set of all sequences $$\alpha:\mathbb{Z}_{\geq 1}\rightarrow \{-1,1\}$$. Let the sequense $$a_n=\prod_{\alpha \in I}\alpha(n)\in [-1,1]^{I}$$. Prove that $$\{a_n\}$$ does not have a convergent subsequence. Is $$[-1,1]^{I}$$ sequentially compact? Is $$[-1,1]^{I}$$ firts contable?
My attempt:
a) Take $$I = \mathbb{N}$$ and $$X_i = \mathbb{R}$$ for all $$i \in \mathbb{N}$$. Now the elements in $$X$$ are real sequences and the goal is to prove that if $$a_n$$ is a sequence of these sequences (i.e. a bi-infinite real sequence), then it converges if and only if the real sequence $$a_n^{(k)}$$ converges for all $$k \in \mathbb{N}$$.
How would the demonstration of the general case be?
b) I don't know
Moderator's note: Thread moved to Calculus & Beyond homework forum.
May be you can start with reminding yourself what it means for a sequence in a topological space to converge, and what the product topology is.
If you put your LaTeX code in [itex] tags, it will be set inline. This takes up less space and makes your post easier to read:
Let \{X_{\alpha}\}_{\alpha \in I} a collection of topological spaces and X=\prod_{\alpha \in I}X_{\alpha} the product space. Let p_{\alpha}:X\rightarrow X_{\alpha}, \alpha\in I, be the canonical projections
a)Prove that a sequence \{a_n\} converges on X if and only if the sequence \{p_{\alpha}(a_n)\} converges on X_{\alpha} for all \alpha \in I.
b) Let I the set of all sequences \alpha:\mathbb{Z}_{\geq 1}\rightarrow \{-1,1\}. Let the sequense a_n=\prod_{\alpha \in I}\alpha(n)\in [-1,1]^{I}. Prove that \{a_n\} does not have a convergent subsequence. Is [-1,1]^{I} sequentially compact? Is [-1,1]^{I} firts contable?
Likes Keith_McClary
... or between pairs of ## tags, which I find easier to type. I don't use the itex ... /itex or tex ... /tex tags at all.
