Prove the Identity (cosecA+cotA)^2 similar to 1+cosA/1-cosA
  • Thread starter Thread starter ibysaiyan
    Identity
The discussion revolves around proving the identity (cosecA + cotA)^2 is equivalent to (1 + cosA)/(1 - cosA). Participants emphasize the importance of correctly interpreting mathematical notation and using parentheses for clarity. The initial approach involves expanding the left side and rewriting it in terms of sine and cosine. After several attempts and corrections, the final steps involve factoring and simplifying to arrive at the desired identity. The conversation highlights the collaborative effort in solving complex trigonometric identities.
ibysaiyan
Hi all , again i am stuck onto this question :( , tried over 3 sheets alone on it lol.btw. thanks for your replies ;) .
hmm let's see.. sin2+cos2=1 ,
sec2= 1+tan2
cosec2= 1+cot2, cot=1/tanx= cosx/sinx
i started off my expanding brackets:
=> cosec2A+cot2A+2cosecAcotA
and the rest well =/ no idea.. i couldn't prove them, just had a thought while typing can't i like sub . some value before expanding them ? ooh =/
Write everything in terms of sinA and cosA, then simplify some more.
Do you mean "=" where you have written "similar to?"
Also, you need parentheses on the right side. What you have would be correctly interpreted as 1 + (cosA/1) - cosA, but I'm pretty sure that's not what you intended.
sec2= 1+tan2
At least give some hint that you are talking about the squares of functions. Without any context sin2 would be interpreted as the sine of 2 radians.
You started with (cscA + cotA)^2. This is equal to csc^2(A) + 2cscAcotA + cot^2(A). When you write cosec2A, most people would read this as cosec(2A) (usually written as csc(2A)).
Ah. again thanks a zillion :)
i think i got it..:
(cosecA + cotA) ^2
(1/SinA + CosA/SinA )^2
=>(1+cosA^2 /sin^2A) <-- i am doubtful about this bit
=> 1+cos2A/1-cos2A
oh sorry about that, next time i will use latex.
i think i got it..:
(cosecA + cotA) ^2
=> 1+cos2A/1-cos2A
Here's what you want to say
(cosecA + cotA) ^2 = (1/SinA + CosA/SinA )^2
= [(1 + cosA)/sinA]^2
When you square 1 + cosA you will have three terms. What you have below has only two terms.
ibysaiyan said:
= (1+cosA^2 /sin^2A) <-- i am doubtful about this bit
yea (a+b)^2 formula so am i on the right track so far?
this is what i got:
[(1+cosA / Sin A )]^2
=> 1+ cos^2A + 2cosA / Sin^2 A
=> hmm would i take cos as common?
ibysaiyan said:
this is what i got:
You are using ==> ("implies") when you should be using =.
You have
\frac{(1 + cosA)^2}{sin^2A}
Leave the numerator in factored form (don't expand it).
Rewrite the denominator using an identity that you know.
Factor the denominator.
Simplify.
AH... thanks a lot , i get it now( much clearer ).
Solved .
Your work that you turn in should look pretty much like this:
(cscA + cotA)^2~=~(\frac{1}{sinA}~+~\frac{cosA}{sinA})^2~=~\frac{(1 + cosA)^2}{sin^2A}~=~\frac{(1 + cosA)^2}{(1 - cosA)^2}~=~\frac{(1 + cosA)(1 + cosA)}{(1 - cosA)(1 + cosA)}~=~\frac{1 + cosA}{1 - cosA}
To see my LaTeX code, click what I have above and a new window will open that has my script.
Roger that , to be honest i can't thank you enough =), anyhow i will be back again ( that's for sure using LATEX code) =).
12K
14K
