MHB Proving $\delta(s,u)+w(u,v)=\delta(s,v)$ in a Shortest Path
  • Thread starter Thread starter evinda
    Path
The discussion centers on proving that for a shortest path from vertex s to vertex v through vertex u, the equation $\delta(s,u) + w(u,v) = \delta(s,v)$ holds true. The proof relies on the relaxation process, where if the distance to u is equal to the shortest path distance from s to u, then after relaxing the edge (u,v), the distance to v will equal the shortest path distance from s to v. It is established that $d[v]$ must be less than or equal to $\delta(s,v)$ and greater than or equal to it, leading to the conclusion that $d[v] = \delta(s,v)$. The key takeaway is that the relationship between the distances confirms the validity of the shortest path property.
evinda
MHB
Hey! (Blush)
I am looking at the proof of the following sentence:
Let $s \to u \to v$ a shortest path from the vertex $s$ to the vertex $v$.
Suppose that we relax at some time the edge $(u,v)$.If,before the call of Relaxation(u,v,w),it stands that $d=\delta(s,u)$,then after the call of Relaxation(u,v,w),it stands that $d[v]=\delta(s,v)$.
The algorithm of the function Relaxation(u,v,w) is the following:
Code:
Relaxation(u,v,w)
 if d[v]>d[u]+w(u,v)
    d[v]<-d[u]+w(u,v)
    p[v]<-u
This is the proof (Wait) :
If $d$ gets at some time the value $\delta(s,u)$,$d$ remains unchanged.After the relaxation,we have:
$$d[v] \leq d+w(u,v) \\ \ \ \ = \delta(s,u)+w(u,v) \\ \ \ \ = \delta(s,v)$$
So,we have: $d[v] \leq \delta(s,v)$.
However, it is known that $d[v] \geq \delta(s,v)$.
So,we conclude that $d[v]=\delta(s,v)$.
Could you explain me why $\delta(s,u)+w(u,v)=\delta(s,v)$ ? (Thinking)
Hi! (Smirk)
Since $s \to u \to v$ is a shortest path, it follows that $\delta(s,u)+w(u,v)=\delta(s,v)$.
I like Serena said:
Hi! (Smirk)Since $s \to u \to v$ is a shortest path, it follows that $\delta(s,u)+w(u,v)=\delta(s,v)$.
I got it now! Thank you very much! (Smirk)
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
