Proving Divisibility by Induction
  • Thread starter Thread starter Jamin2112
    Induction Proofs
Jamin2112
Here are some that I'm stuck on.
Pg. 56, #12
Prove by induction on n that, for all positive integers n, 3 divides 4^n + 5
Of course, the base case it is P(1) = (4^1 + 5) / 3 = 9/3 = 3...TRUE!
I just can't see the trick here. P(K+1)= (4^(K+1) + 5) / 3 = ((4)(4^K) + 5)/3= ... not getting anywhere, really.
Pg. 55, #17
For a positive integer n the number An is defined by
A1=1 [supposed to A with a subscript 1]
Ak+1 [supposed to A with a subscript k+1] = (6Ak+5)/(Ak+2)
Prove by induction on n that, for all positive integers (i) An>0 and (ii) An<5
I see by long division that we have
Ak+1=1-7/(Ak+2)... not sure if that helps. I know that Ak+1 will be zero with Ak=5...no sure if that helps though...
#12) Consider adding 0 in a creative way...so that you can factor out a 4 completely and have the sum of two numbers that are both divisible by 3.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
