Proving \{ \gamma^5 , \gamma^\mu \} = 0 to Gamma 5 Matrix Verification
  • Thread starter Thread starter latentcorpse
    Gamma Matrix
The discussion centers on verifying the anticommutation relation \{ \gamma^5, \gamma^\mu \} = 0. The initial calculations suggest that additional terms arise when manipulating the gamma matrices, particularly due to the properties of the metric tensor \eta^{\mu\nu}. The key argument involves rearranging the gamma matrices to bring identical indices together, which introduces sign changes with each swap of non-matching indices. Additionally, there is a side conversation regarding the relationship between the Lagrangian and Hamiltonian formulations in quantum field theory, emphasizing that the Hamiltonian is derived from the Lagrangian through the Legendre transformation. The thread concludes with clarifications on the definitions and relationships between the Lagrangian and Hamiltonian.
latentcorpse
How do I verify \{ \gamma^5 , \gamma^\mu \} = 0
I have
\{ \gamma^5 , \gamma^\mu \} = \gamma^5 \gamma^\mu + \gamma^\mu \gamma^5
= -i ( \gamma^0 \gamma^1 \gamma^2 \gamma^3 \gamma^5 + \gamma^5 \gamma^0 \gamma^1 \gamma^2 \gamma^3 )
= -i ( \gamma^0 \gamma^1 \gamma^2 \gamma^3 \gamma^5 - \gamma^0 \gamma^5 \gamma^1 \gamma^2 \gamma^3 )
= -i ( \gamma^0 \gamma^1 \gamma^2 \gamma^3 \gamma^5 + \gamma^0 \gamma^1 \gamma^5 \gamma^2 \gamma^3 )
= -i ( \gamma^0 \gamma^1 \gamma^2 \gamma^3 \gamma^5 - \gamma^0 \gamma^1 \gamma^2 \gamma^5 \gamma^3 )
= -i ( \gamma^0 \gamma^1 \gamma^2 \gamma^3 \gamma^5 + \gamma^0 \gamma^1 \gamma^2 \gamma^3 \gamma^5 )
But this is not quite right, because at some point I will have shifted the \gamma^\mu past itself and so I will get an additional term +2 \eta^{ \mu \mu} since \{ \gamma^\mu , \gamma^\nu \} = 2 \eta^{\mu \nu}
So I should get three terms:
= -i ( \gamma^0 \gamma^1 \gamma^2 \gamma^3 \gamma^5 + \gamma^0 \gamma^1 \gamma^2 \gamma^3 \gamma^5 -2 \eta^{\mu \mu} \gamma^0 \gamma^1 \gamma^2 \gamma^3 \gamma^5 )
and then
= -i ( (2-2 \eta^{\mu \mu}) \gamma^0 \gamma^1 \gamma^2 \gamma^3 \gamma^5) \neq 0 since \eta^{\mu \mu} = 4, no?
So you have to prove that
<br /> \gamma^0 \gamma^1 \gamma^2 \gamma^3 \gamma^{\mu} + \gamma^{\mu} \gamma^0 \gamma^1 \gamma^2 \gamma^3 = 0<br />
The main idea is to get matrices with identical indexes close to each other.
Note that
1. every time you switch two \gamma's with \mu \neq \nu you get a minus sign
2. if you have to move \gamma^\mu in the first summand k times to the left, you will have to move it in the second summand (3-k) times to the right, thus giving ou additional (-1)
Note that
Thanks. Can I also ask, why equation 3.25 is correct? Isn't that the interaction Lagrangian instead of the interaction Hamiltonian? I think you'll need to look at eqn 3.7 as well.
Cheers.
em... which book? =)
It comes right from the connection between hamiltonian and lagrangian.
If you have for lagrangian L = L1 + L2 and L2 does not depend on derivatives, then for hamiltonian you have H = H1 + H2, where H1 corresponds to L1 and H2 = -L2.
Even more, if you have infinitesimal addition (that can depend on derivatives) to lagrangian: L = L0 + L', then for hamiltonian H = H0 + H', where H0 corresponds to L0 and H' = -L'.
when you say H0 correspsonds to L0, do you mean H0=L0? Or it is just some function of L0?
H0 can't be equal to L0, because they don't depend on the same (field) variables. For the system without constraints, the Hamiltonian is the Legendre transformation of the Lagrangian wrt the generalized velocities.
