MHB Proving Inequality for All $n \ge 1$
  • Thread starter Thread starter tmt1
    Inequality
The inequality $$ \frac{n^3}{n^5 + 4n + 1} \le \frac{1}{n^2} $$ holds for all integers $n \ge 1$. The reasoning involves showing that the denominator $n^5 + 4n + 1$ is always greater than $n^5$ when $n \ge 1$, allowing the inequality to be manipulated. By rearranging and taking reciprocals, it is established that $$ \frac{1}{n^5 + 4n + 1} \le \frac{1}{n^5} $$ leads to the desired conclusion. The condition $n \ge 1$ is necessary to avoid undefined expressions and ensure the inequality remains valid. Thus, the original inequality is proven true for all natural numbers starting from 1.
tmt1
I have this inequality:
$$ \frac{n^3}{n^5 + 4n + 1} \le \frac{1}{n^2}$$
for all $n \ge 1$
I get that
$$ \frac{1}{n^5 + 4n + 1} \le \frac{1}{n^2}$$
but how do I guarantee that when $n^3$ is in the numerator, this inequality holds? Is this for any numerator greater than 1? Also, why must $n$ be greater than or equal to 1?
Mathematics news on Phys.org
Rearrange the left-hand side like so:
$\dfrac{n^2}{n^2}\cdot \dfrac{n^3}{n^5 + 4n + 1} = \dfrac{1}{n^2}\cdot\dfrac{n^5}{n^5 + 4n + 1} < \dfrac{1}{n^2}$
whenever $n^5 + 4n + 1 > n^5$, that is, when $4n + 1 > 0$, so $n > -\frac{1}{4}$.
If $n$ is an integer, this means $n$ must be non-negative. But we cannot allow $n = 0$, or else the RHS of the inequality is undefined. That leaves $n \geq 1$ (unless you want to make some awkward qualifications about when $n = 0$).
The inequality still holds for all non-zero reals $n$ greater than $-\frac{1}{4}$, but the use of the letter $n$ typically indicates a natural number.
Since n is positive, if if were true that $$\frac{n^3}{n^5+ 4n+ 1}\le \frac{1}{n^2}$$ then, multiplying by [math]n^2(n^5+ 4n+ 1)[/math] we would have [math]n^5\le n^5+ 4n+ 1[/math]. That is the same as [math]0\le 4n+ 1[/math] which, since n is positive, is true. To prove the original statement, work back. It is true that [math]0\le 4n+ 1[/math]. Add [math]n^5[/math] to both sides to get [math]n^5\le n^5+ 4n+ 1[/math]. Now divide both sides by [math]n^2(n^4+ 4n+ 1)[/math].
tmt said:
I have this inequality: $ \frac{n^3}{n^5 + 4n + 1} \le \frac{1}{n^2} $ for all $n \ge 1$
I get that.
\begin{array}{cccc}\text{For } n &gt; 1, &amp; 4n + 1 \:\ge\:0 \\ \\<br /> \text{Add }n^5: &amp; n^5 + 4n+1 \:\ge\:n^5 \\ \\<br /> \text{Take reciprocals:} &amp; \dfrac{1}{n^5+4n+1} \:\le \:\dfrac{1}{n^5} \\ \\<br /> \text{Multiply by }n^3: &amp; \dfrac{n^3}{n^5+4n+1} \:\le \: \dfrac{n^3}{n^5} \\ \\<br /> \text{Therefore:} &amp; \dfrac{n^3}{n^5+4n+1} \:\le\: \dfrac{1}{n^2}<br /> \end{array}
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
