Proving Kähler, finding the Kähler form
  • Thread starter Thread starter Mak182
    Form
Mak182
Hi!
I have a question about Kähler manifolds. Of course there are many books (I prefer Nakahara) and lecture notes on this topic, but as a physicist I need a very hands-on way of dealing with metrics, etc.
Given a metric, what is the simplest way to find the Kähler form and to prove the Kähler property? I mean, e.g. Nakahara describes Kähler, but is there something simpler one can do (perhaps just in some cases)?
An example I have encountered is
\begin{equation}
ds^2 = (r-u) \left(\frac{\text d r^2}{F(r)} -\frac{\text d u^2}{G(u)} \right) + \frac{1}{r-u} \left(F(r) (\text d t +u \text d z)^2 - G(u) (\text d t+ r \text d z)^2 \right) ~,
\end{equation}
where $F$ and $G$ may be any functions of one variable. This metric is claimed to be Kähler with Kähler form
\begin{equation}
\Omega = \text d (r+ u) \wedge \text d t + \text d (r u) \wedge \text d z ~,
\end{equation}
which is obviously closed.
Following Nakahara, one needs to change coordinates to make the metric Hermitian, but can the Kähler form be read off more directly?
Cheers!
Given a Riemannian metric ##g(X,Y)## and an almost complex structure ##J##, the Kahler form is defined as ##\Omega(X,Y) = g(JX,Y)## (eq (8.55) in Nakahara). The Kahler form will be closed if the almost complex structure is covariantly constant in the Riemannian metric. I'm not sure what complex structure is being used in the example you gave, but it's probably straightforward, if tedious, to work it out.
Adding to what fzero said: You first need to find the complex structure and show that it is integrable. For a generic metric, this might be rather non-obvious. But in most actual applications, the metric is written in such a way that the complex structure is easy to see.
What one does, generally, is to write the metric in terms of orthonormal frames. Then you know that the almost-complex structure must simply rotate these frames. In your example, the metric is already a sum of four squares, so the hard work is already done.
Looking at your metric, it can have signature (++++), (++--), or (----), depending on the signs of F and G. In order to apply complex geometry, you must group things in pairs that have the same signature. So the two terms with ##F(r)## in front go together, and the two terms with ##G(u)## go together. From here it should be easy to postulate an almost-complex structure J. Then you apply standard techniques to show that J is integrable.
Finally, given J, the Kahler form is well-defined.
Hello! There is a simple line in the textbook. If ##S## is a manifold, an injectively immersed submanifold ##M## of ##S## is embedded if and only if ##M## is locally closed in ##S##. Recall the definition. M is locally closed if for each point ##x\in M## there open ##U\subset S## such that ##M\cap U## is closed in ##U##. Embedding to injective immesion is simple. The opposite direction is hard. Suppose I have ##N## as source manifold and ##f:N\rightarrow S## is the injective...
