MHB Proving Rationality of Squares of 9th Day 2 ARO 2004/2005 Numbers
The discussion revolves around proving that the squares of ten mutually distinct non-zero real numbers are rational, given that for any two numbers, either their sum or their product is rational. Participants explore various cases and mathematical relationships, attempting to derive contradictions based on the assumptions of rationality. A key point raised is that if certain sums or products are rational, it leads to implications about the rationality of other combinations, ultimately affecting the original numbers. The complexity of the proof is acknowledged, with suggestions for considering multiple cases to reach a conclusion. The conversation highlights the challenge of navigating the conditions set by the problem while striving for a rigorous proof.
Smb
Ten mutually distinct non-zero reals are given such that for any two, either their sum or their product is rational. Prove that squares of all these numbers are rational.
I tried using 3 of those numbers - a, b and c. And I checked each of the possible situations but I'm not sure if my maths teacher is going to accept it.
The problem is from the All-Russian Olympiad 2004/2005 9th Day 2.
Mathematics news on Phys.org
Is this a homework assignment? If so, I recommend you post as much working as possible.
I worked out the answer easily but the method is slow.
I'll write for the first one because I don't have much time now:
a+b(-Q
b+c(-Q
a+c(-Q
ab+bc+ac+b^2(-Q
ab+bc+ac+c^2(-Q
(b-c)(b+c)(-Q
b-c(- Q Analogically we can do for each pair of numbers.
b^2-2bc+c^2-B^2-2bc-c^2(-Q
=> bc (- Q Analogically we can do for each pair of numbers. =>
b^2(- Q Analogically we can do for each pair of numbers.
a+b(-Q
b+c(-Q
a+c(-Q
ab+bc+ac+b^2(-Q
ab+bc+ac+c^2(-Q
(b-c)(b+c)(-Q
Hi Smb! Welcome to MHB! (Smile)Whatever way I can think of, it seems to be a number of cases, although I think we can do with fewer than you are suggesting.
Still, if we could cover all 8 similar cases we would be done, although I don't think we can.For starters, what you have now cannot occur, since if we start with $\def\inQ{\in\mathbb Q}
a+b, a+c \inQ$, then it follows that $(a+b)-(a+c) = (b-c) \inQ$.
Now suppose $b+c\inQ$, then $\frac 12((b+c)+(b-c))=b\inQ$ and similarly $c \inQ$, so that $bc\inQ$, which contradicts the either-or.
Therefore $b+c\not\inQ$.Let's start with assuming that we can find a triplet $(a,b,c)$ with $ab,ac\inQ$.
Then $\frac {ab}{ac}=\frac bc \inQ$, isn't it?
Now suppose $b+c\inQ$, then $\frac bc\cdot c + c = (\frac bc + 1)c \inQ$.
Can we figure out from there if any of $b$, $c$, and in particular $bc$ is rational? (Wondering)
And if so, can we find that $a^2\inQ$?
I forgot to rewrite it! I'm sorry for the misunderstanding it can be and/or.Both b +c(-Q and bc(-Q could be a case..
Fair enough. The proof doesn't really change though. Just a couple more cases to consider.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
