Proving the Binomial Theorem for Natural Number Exponents using Induction
  • Thread starter Thread starter masterofthewave124
    Sequences Series
masterofthewave124
For the geometric sequence with tn = 2(-1)^n*(1/3)^n
(a) the sum of the first 99 terms
(b) the sum of the odd-numbered terms t1 + t3 + t5 +...+ t99
(c) the sum of the even-numbered terms t2 + t4 + t6 +...+ t98
so do i first maybe want to convert that into something simpler? why would they write it like that in the first place. a = -2/3, r = -1/3 so wouldn't
tn = (-2/3)(-1/3)^(n-1)?
anyways, after doing that, should i turn that equation into Sn = ?
how would i do b) and c)?
Yes, the general term can be written either way: or even as 2(-1/3)^n which I would consider simpler still. Now use the formula to find S99[/b].
For b and c, write out a few terms and see if you can't write those also as a geometric series with a different a and r.
ok, i got -1/2, -3/4 and 1/4 for a), b) and c) respectively...are these rounded numbers? simply because as n approaches infinity, the terms become more rational? i see that the relationship is the sum of the sums found in b) and c) equals the sum found in a) so i guess its correct (i..e -3/4 +1/4 =1/2). now what would be the sum of the reciprocals of the terms for the first 99 terms? for this one, a = -3/2 and r = -3 so Sn = (3/8)*((-3)^n-1) correct? but the sum this time is not a nice number, i get -6.44 x 10^46, can anyone verify that?
i have another question;
use mathematical induction to prove the following:
http://img90.imageshack.us/img90/7200/induction2li.jpg
can this be restated as this:
n!/(n-0)!0! + n!/(n-1)!1! + n!/(n-2)!2! + n!/(n-r)!r! = 2^n?
how would i prove true for n = k+1?
i have
LS = 2^k + (k+1)!/(k+1-r)!r!
RS = 2^(k+1)
are those correct and if so, where do i go from here?
Uhmmm, not pretty sure if it can be Proven by Induction. However, if you notice that 2n = (1 + 1)n, and use the Bonimial Expansion, the problem works out nicely. :)
And no, it should not be -1/2, -3/4, and 1/4 for the firstproblem. They are all rounded up, it should be some rounding error with the calculator. -1/2 is the sum of the series as n tends to infinity, not for n = 99.
So:
t_n = 2 \times \left( - \frac{1}{3} \right) ^ n
S_n = \sum_{k = 1} ^ n t_n
So the sum of the first 99 terms of the series is:
S_{99} = -\frac{2}{3} \times \frac{\left( - \frac{1}{3} \right) ^ {99} - 1}{- \frac{1}{3} - 1} = -\frac{2}{3} \times \frac{ - \frac{1}{3 ^ {99}} - 1}{- \frac{4}{3}} = \frac{1}{2} \times \left( - \frac{1}{3 ^ {99}} - 1 \right)
You can just do the same for b, and c.
Can you go from here? :)
i have
RS = 2^(k+1)
Find a non-inductive algebraic proof of [k,r] +[k,(r-1)] = [(k+1),r]. This shouldn't be too difficult, just simplify and bring everything under one denominator.
After you get that result, the rest is easy.
2^{(k+1)} = 2(2^k) = 2 \sum_{r=0}^{k}[r,k] = 2S(k)
Where S(k) represents the summation. Expand out the summation term-wise and instead of simply multiplying by two, write it in the form S(k) + S(k). Add in a "staggered" fashion - the second term of the left hand sum to the first of the right hand sum and use the previously proven result to simplify. The remaining two terms can be expressed in a similar fashion to fit in with the form of the series. You will find that the result is of the required form S(k+1), proving the result.
This, in fact, is how you would go about proving the Binomial Theorem for natural number exponents using induction. I'm simply adapting the method to this. BTW, I don't think you can assume the Binomial Theorem and just write down the answer as VietDao suggests, I believe the question is asking for a more involved proof like the one I've suggested.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
